I Need Help 400 not working
Old May 10, 2013 | 08:45 PM
FordF350Guy's Avatar
FordF350Guy
I rebuild my 400 sb and now it has an off idle bog and high end sputter along with, what feels to be huge loss in power. I have done everything that I can think and I just cant figure it out anything helps.
Engine is bored out 30, heads port/polish, edelbrock performer 400, holley 770 truck avenger, 7 PSI 98 GPM electric fuel pump, Crane Cams RV cam and lifters, blueprinted and balanced crank, flat top pistons, MSD ignition (except distributor, have the cap and button) high volume oil pump, high volume water pump, exhaust headers and more
Checked the Accelerator cam and tried 4 other ones
checked conconnection to the Accelerator pump= no play and right tolerance.
Cam degree is good.
engine gets fuel
vacuum is like 10
Ive tried different timing degrees from 8-20 advance, no change just harder to start
have not checked my compression yet but it should be good everything is new.
everything on the engine has been grounded.
Air fuel screws are 1-1/4 out equal both sides. For the highest vacuum.
Summit racing said it might be like 25 things starting with transition valve or something.
Engine is also running really weak for all I have in it. I need help
Old May 10, 2013 | 08:57 PM
Franklin2's Avatar
Franklin2
I would check compression. It may not be good. How much have to ran it? Does it smoke any that you notice? Sometimes it takes a little bit for it to break-in, especially if the correct cylinder finish was not done.
How much of this did you do yourself?
Old May 10, 2013 | 09:03 PM
1983F1503004x4's Avatar
1983F1503004x4
Have you checked for all the obvious things first? No vacuum leaks? Intake manifold and carb/carb spacer, etc. all tight?
Where is your idle set at? What size power-valve? What size jets? Are the floats set correctly? Etc.
Have you tried timing it with a vacuum gauge? Is the vacuum advance hooked to the right port?
There's no reason why you're having a stumble and low vacuum. Either too much fuel or not enough, and it sounds like too much fuel.
Do you have a 600 or 650 CFM carburetor you could put on and try? The 770 CFM might be wrong for the 400.
Is your cam timing right as well?
Old May 10, 2013 | 10:57 PM
weskan's Avatar
weskan
Look down the carb while the engine is idling. If you see fuel coming out of the venturis, then you might have to adjust the float level. If that doesn't fix it, then the fuel pressure might be too high, try backing it down to 4-5 psi.
If the cam of the engine is big enough to have a lope at idle, then get a power valve that is rated for a lower vacuum application.
Old May 11, 2013 | 01:01 PM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
770 cfm is a bit big for a truck, the 460s only came with a 600 and the old 428CJ came with a 735cfm.
Old May 11, 2013 | 03:35 PM
Franklin2's Avatar
Franklin2
I would put the carb being too big down on the list. It should adjust itself somewhat if it's a vacuum secondary carb. The vacuum being that low is a sign, you just have to figure out what's causing it. Many things could cause it.
Old May 18, 2013 | 07:58 AM
FordF350Guy
I think i found my problem. I checked the compression and Im down at 50 on #7and 98 on #3 so then i looked at my valvetrain and it seems to be fine so i put a little oil in the hole and she jumped to 125 like the rest of them. So i found a guy to put in new rings hopefully that will fix it
Old May 18, 2013 | 09:22 AM
1983F1503004x4
If your engine was bored 0.030 over, then it should have 30 over pistons with a new set of fresh rings.
Something is wrong with the rebuild. I'd pull the whole thing apart and re-check it ALL.
Is it possible your rings weren't put on right or haven't seated correctly?
Old May 18, 2013 | 09:26 AM
ctubutis's Avatar
ctubutis
Yes, the rings have a top and a bottom and need to be installed correctly, not upside down.
Old May 18, 2013 | 04:20 PM
85lebaront2
Also not broken during installation.
bobs 80 f250
Jun 14, 2019 01:06 PM
NMFirstF2504X4
45
Mar 14, 2014 08:02 PM
Scott Walter
Apr 24, 2013 08:44 AM
chumley360
Jun 14, 2009 07:17 PM
craig429
Jan 6, 2002 03:44 AM
