Dana 44HD breaks dragging
I put the new hose on, hooked it up to the other new caliper with fresh washers, and a new banjo bolt. No seal at all, just leaks and leaks.
Put the old caliper back on with it's old washer still pressed into it. No leak, with very little torque.
Took off the old calipers washer and the concentric grooves are all there, and in good shape.
The new calipers don't have any, they've been covered with some kind of coating the caliper was sealed with. I can't imagine any of these calipers ever working. I guess I'll have to take them back.
Either way I don't assume the washer would seal against that kind of texture.
Sorry. That must be really frustrating.
I put the drivers side caliper on and so far no leaks. I'm going to bleed them tomorrow and get it all back together. Hopefully the seal holds.
I've always had really good luck at Carquest too. Anytime I've gotten something defective, they replace it with whatever top of the line item they can find because they don't want it to happen again. I've never gotten that kinda service at O'Reilly's or Napa in my area.
It took a long time to get the air out of the line. I've made sure that the reservoir never got down below the add line during any part of the process, but there was a lot of air in the line.
I eventually pumped it out (or it seems to have), because the fluid is clean and there are no more bubbles.
When I close the bleeder screw there doesn't seem to be any movement from the pistons when I press the pedal. the pedal isn't really soft but it still goes to the floor.
How do I proceed? Should I keep bleeding?
If it goes to the floor now, it will likely fall to the floor with the engine running and the booster working.
Try tapping on the calipers and lines with a screwdriver handle.
This will help bubbles rise that might be clinging to the insides.
They are not meant to extend that far.
Perhaps with brand new pads the pistons won't pop out or allow the seals to leak fluid into the boots, I'm not sure...
Put the calipers on, as in fully mount them. Then bleed the brakes. The pedal should firm right up.
Yep, I've done quite a lot with engines and a little with transmissions but never anything axle related. A friend of mine was driving this truck as a work truck, and I noticed he was downshifting a lot and when I asked he said it had very little brakes, but was able to get by because the IDI and a 5-speed are pretty good for engine braking. Since it had no material on the fronts, and also was missing a lot of metal from the rotors, and also quite a lot off the pad plates I think it had just been braking on the rear drums. Probably for some time.
I didn't want him driving the truck, because it just wasn't safe so I offered to try and fix it. When I saw it was going to be expensive I went ahead and bought it off of him. I grew pretty attached to the IDI, and the ZF and even the TTB, which rides nicer than my DD which is a 2500HD GMC with the TB IFS. Gets a lot better mileage too.
It also needs a new t-case (leak), and joints, and pinion seals but overall it's a really solid truck, and the frame is in great shape for up here. I think it'll be a fun project.
I have a spare set of rotors I bought before I decided to buy wheel hubs.
If I take the wheelhub/rotor assembly off do I have to replace the wheelhub seal (the one at the very back) every time? Or just when it's worn out.
And how much would most shops charge to press out the studs and swap the spare rotors onto the new wheelhubs. I'm guessing both sides need to be the same rotor and the spare ones are slightly thicker.
How far did you drive it 'up and down the road'???
You can check with a dial indicator, or a shop with a brake lathe can check it for you.
If you need to get the bearing out you need to change the seal too.
Wipe some of that extra grease off the caliper mount.
It just needs a thin film.
You don't want it to get onto the friction surface.
Personally, I would just get the brakes mounted back on the truck (like I said in post #5) and bleed them with the nipple at the high point and then take it for a drive.
Try not to drag the brakes, make any panic stops right away.
The new pads and rotors need to settle into one another without glazing.
This is all $$$ you could be using to address some of the other issues.
Good luck and enjoy your new Ford truck.
