Powerstroke common problems
Old May 7, 2013 | 08:09 PM
Pequeaford's Avatar
Pequeaford
I'm looking at a mold year 98 f250 7.3 powerstroke 5spd ext cab long bed. Is there any common problems I should look and listen for when I look at it and how is it a 98 with the body style from 92-97
Old May 7, 2013 | 08:20 PM
F350-6's Avatar
F350-6
There was no 98 model year on the F250. Ford skipped from 97 to 99.
Old May 7, 2013 | 08:29 PM
fordman67's Avatar
fordman67
Is it obs or sd body style?
Old May 8, 2013 | 06:38 AM
Pequeaford's Avatar
Pequeaford
The ad says 98 so it's a 97 mold year kind of deal. It has the same front end as my 95 f150
Old May 8, 2013 | 07:13 AM
fordman67's Avatar
fordman67
98 I'm betting is sd body style.
Old May 8, 2013 | 09:30 AM
Pequeaford's Avatar
Pequeaford
Ok so if it is an sd does anyone know any common problems for them that I should look for when I drive it. This will be my first diesel.
Old May 8, 2013 | 09:44 AM
CampSpringsJohn's Avatar
CampSpringsJohn
Check out this thread.
https://www.ford-trucks.com/forums/5...questions.html
2nd post in this thread.
https://www.ford-trucks.com/forums/1...250-7-3-a.html
Old May 8, 2013 | 10:13 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
Yeap. Only made 98 model year E series
Old May 8, 2013 | 10:16 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Lightbulb
If it has the same front as your 95, is not a SD, its an OBS, probably 97 model year, with wrong advertisement.
Anyway the links posted above will help you in both cases.
Old May 8, 2013 | 10:28 AM
superduty4x4's Avatar
superduty4x4
Chris is partially right. There was no 98 model HD F-250 made.... only the spaceship looking silly little light duty F-250.
But if the truck has the 7.3 in it... then it's either a 97 or 99. Either way, I wouldn't buy it since the guy selling it obviously has no flippin' clue what he even has.
Old May 8, 2013 | 11:26 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Arrow
No, I think Chris is totally right, the OP said: "f250 7.3 powerstroke 5spd ext cab long bed" and also said (as I mentioned above):"It has the same front end as my 95 f150", so for me is an OBS not a SD
Old May 8, 2013 | 01:23 PM
FI460's Avatar
FI460
What chase is saying is there were 98 f250s. They were essentially f150s though. This does not sound like one.
Old May 8, 2013 | 05:29 PM
madpogue's Avatar
madpogue
The 1998 "Light Duty" F250 (why on earth they didn't just call it an "F200" is ) never came with a Powerstroke engine.
The REAL key to the answer is -- what is in the 8th position of the VIN? That, regardless of the date of manufacture, the shape of the front end, the phase of the moon, the number of pennies in the ashtray, etc., determines the model year.
And actually, the cluelessness of the seller may work in your favor. Not that you would (ahem) intentionally take advantage of him (cough), but it may turn out to be a very nice truck that the seller thinks is some strange mid-year (I hope it's really not a "mold year" truck....) mongrel for which it's impossible to find parts or something.
Though all this silly banter does actually point to one of the "common problems" with the '97s (if that's indeed what it is), and that is, getting parts stores to sell you the right part. Powertrain stuff is usually right on, but if you're looking for a body/chassis part and say it's a '97 F250, or just a '97 Ford, you may end up with the wrong part. BEST thing to do is do your own homework, nail down the correct part NUMBER you need, and walk in armed with the info.
Old May 8, 2013 | 07:05 PM
F350-6's Avatar
F350-6
So now that it sounds like a 97 or earlier, I would be suspicious and check out anything and everything possible. If the seller doesn't even know what year model the truck is, what else did he not know or ignore while he owned it?
Old May 8, 2013 | 07:42 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
That was funny.
I have read that IF you have a 97, is better so say that is a 96 model, but you are rignt about the last part of your comment.
