Alternator belt length
Old May 7, 2013 | 11:42 AM
Sooper Camper's Avatar
Sooper Camper
truck is a 77 F350 with a 460, and it had AC at one point.
the belt that is currently on the alternator is small, it only wraps the crank pulley and the alt pulley. the parts store guy measured it and it measures out to a "lawnmower" belt. the belt his computer spit out was way too long..
can someone take a picture of their similar setup, or post a factory diagram of how the belt is supposed to be routed? as it looks right now, i'd have to move the alternator forward ~1.5" to get it in front of the Power Steering belt. the crank pulley has 3 grooves, and the power steering rides on the middle, lines up fine and the belt they sold me works perfect for that one.
Old May 7, 2013 | 03:51 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1977 F150/350 460 with P/S & Factory Installed Integral A/C without T/E (Thermactor Emission-smog pump).
Factory A/C combined with the heater, A/C controls located in same panel as heater controls.
C9PZ-8620-F .. Alternator Belt (Motorcraft JB-354) / 15/32" x 35 1/2"
DOAZ-8620-E .. P/S Belt (Motorcraft JC-527-L) / 1/2" x 52 7/8"
C9PZ-8620-CC .. P/S Idler Pulley Belt (Motorcraft JC-465) / 1/2" x 46 5/8"
C9PZ-8620-CV .. A/C Belt (Motorcraft JC-564) / 1/2" x 56 1/4"
Old May 7, 2013 | 09:26 PM
Poison Oil Racing's Avatar
Poison Oil Racing
what more do you need?
Old May 7, 2013 | 10:08 PM
Sooper Camper
Got it sorted. Parts store had the wrong belt in the right package, now everything is bueno. I know it only technically needs to wrap the 2 pulleys, but seeing the other 2 accessories wrapped 3 i just wanted to make sure. The truck has seen more than its share of farm fixes, just wanted to make sure the belts were routed properly.
Number dummy, do you have all these part numbers memorized???
Old May 7, 2013 | 10:32 PM
NumberDummy
Originally Posted by Sooper Camper
NumberDummy, do you have all these part numbers memorized???
Belt part numbers taken from 1973/79 Ford Light Truck Parts Catalog.
Big Skier
31
Feb 27, 2019 07:21 AM
atvmax99
May 28, 2016 10:15 AM
beatnbronco
1978 - 1996 Big Bronco
Nov 11, 2013 09:34 PM
wgotthardt
1997 - 2003 F150
Jul 23, 2009 10:56 AM
wtroger
Aug 31, 2004 08:53 AM
