Quick temp fix for radiator?
Old Jun 6, 2003 | 09:24 PM
Franken-Truck's Avatar
Franken-Truck
I have a small crack on the driver side radiator tank along the front edge were its tabbed down. Its about 4 inches along and its high enough above the water pump that it loses little water and the engine still runs cool. But summers starting to heat up, and I would like to make sure it lasts 2 weeks or so until I get payed again. Is there anything I can do? The radiator stop leak stuff didn't help much. Can It be siliconed(high temp stuff) or glued, maybe with some epoxy? Like I said before, this is a temp fix, till I have a few spare bucks for a new one. I have an 87' F-150, I6 with a 2 row radiator.
Old Jun 7, 2003 | 12:21 PM
steve83's Avatar
steve83
There's no good way to fix the plastic tanks. Buy a lifetime direct replacement as soon as possible.
Old Jun 7, 2003 | 12:52 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
I've had good luck with Alumaseal (I think that's what it's called), the silver powder in the ~1" round by about 3 1/2" long tube. However, I've never tried it on a radiator with plastic tanks. One word of caution here; I've had the stuff fail unexpectedly and when it did the seam between the tank and the core unzipped about 10 inches. However, it did take maybe 6 months for this to happen. The engine had only been running for about 1 1/2 miles on a cool morning too. Just beware.
Old Jun 7, 2003 | 11:49 PM
Franken-Truck
$170 bucks from AutoZone. Just need the money Maybe I can borrow some money..........Though this wouldn't be an issue if I hadn't just payed this semesters tuition One other thing, what are the plastic tanks made of?
Old Jun 10, 2003 | 10:16 PM
oldfordtrucksrule's Avatar
oldfordtrucksrule
if you can find a can of wynn's cooling system stop leak put it in. thats the stuff they put in after a cooling system flush with the machine they hook up to your radiator hose to flush out all your old coolant. i have seen this stuff seal a leak that was running and spraying water out of the radiator. it sealed it good. its made from ground up cactus. go to shop's that have the wynn's flush service and ask to buy a bottle of the stop leak. they might sell you one. thats the best thing you can do to fix it for now in my opinion.
Old Jun 11, 2003 | 11:48 AM
Franken-Truck
Thanx for the info, but I scrounged and went ahead and buoght it. Just getting ready to go drop it in
schrabs0
May 28, 2017 09:04 AM
hooler1
23
Sep 3, 2011 10:42 PM
Davemandu
May 1, 2011 04:48 PM
flamebuster
Dec 28, 2009 12:24 AM
Rusty_S
15
Jul 25, 2009 06:34 PM
