2005 Excursion Limited V10 overheating
Old May 28, 2017 | 08:06 AM
schrabs0's Avatar
schrabs0
My excursion started overheating several months ago. The radiator needed to be replaced. This was done and a complete system flush was done along with an air lock check. Everything worked until the ac was turned on, then the gauge showed it was overheating but laser temp sensor showed it was not overheating. I had the water pump, temp sensor, thermostat and clutch fan replaced. Vehicle still shows overheating and will go into limp mode but it actually is not overheating because you can take the radiator overflow cap off and laser sensor shows normal temp. I am thinking its electrical. I have not replaced the temp sender yet. It only shows overheating when I turn the A/C on. When I shut the ac off, the gauge goes back to normal. What else can I do?
Old May 28, 2017 | 09:04 AM
Romanova's Avatar
Romanova
You need an OBD2 reader to see what the actual coolant temperature is. Would also replace the temp sender and see what that does.
phishfood4311
Modular V8 (4.6L, 5.4L)
Sep 9, 2015 06:01 AM
Berriemaas
Sep 7, 2014 02:17 PM
Ridenred333
Modular V10 (6.8l)
Apr 28, 2013 02:30 PM
john_picinich
1997 - 2003 F150
Oct 20, 2006 02:28 PM
broncoray
Bronco II
Dec 31, 2003 03:14 PM
