Somethings Squeaking...?
Old May 6, 2013 | 04:38 PM
Bryanblaylock's Avatar
Bryanblaylock
1977 f150 4x4
I got something squeaking...
I think its something behind the cab and i was wondering what to grease.
It squeaks when i drive and i can hear it at low speeds. I guess something in the diff (ford 9).?
Does anybody have a diagram of what to grease or lube? thanks
Old May 6, 2013 | 05:09 PM
RunninD's Avatar
RunninD
does it speed up as you do? is it more noticeable when you first start moving? might just be a U-joint. That's what mine was.
Old May 6, 2013 | 05:15 PM
Fordboy88's Avatar
Fordboy88
x2 on the u joint. jack up the rear end and put some jack stands under it where the tires are a few inches off the ground and put the truck in gear. Then you can get under it and see if you can locate the squeak. does not hurt to have someone inside and the front wheels chocked when this is going on
n8ter88
Apr 23, 2012 11:49 AM
sudsmcduff
Jul 28, 2010 12:35 AM
b4hntn
1978 - 1996 Big Bronco
Jul 26, 2010 05:19 PM
brider
Sep 28, 2006 10:16 PM
dennisjoslin
Jan 29, 2003 08:35 PM
