Rear brake issues
Old May 5, 2013 | 07:36 PM
garrettsr5's Avatar
garrettsr5
Rear brake issues
So I did rear brakes on my truck. Had to impromptu do the right rear axle hub seal and bearings too.
New shoes, wheel cylinders and hardware. Take it for a spin and uh oh! Pedal goes to the ground.
Take a peak underneath and realize the left rear flare nut is loose. Retighten the nut.
I went for a drive today to get some dinner and the pedal mushy. I pumped it up and it got a little better then locked the rear axle.
I tried this twice with the same result.
what gives?
Old May 5, 2013 | 07:44 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
did you re-bleed the brakes after tightening the line/
Old May 5, 2013 | 07:50 PM
Aune163rd's Avatar
Aune163rd
Sounds like a vacuum issue.... Bleed brakes then retry
Old May 5, 2013 | 08:40 PM
Chevy_Eater's Avatar
Chevy_Eater
You have a bigger problem, even with your rear line disconnected that should not have affected your front brakes, which do most of your stopping. Your pedal should not go to the floor no matter what shape your rear brakes are in as long as your fronts are functioning correctly.
If you're lucky a good bleeding on all 4 wheels will be all you need.
Old May 5, 2013 | 08:48 PM
Aune163rd's Avatar
Aune163rd
I second that... Don't make sense to have little to none at one push... If you pump it and it works then locks them up you got air in the lines
Old May 6, 2013 | 07:18 AM
regidog's Avatar
regidog
Also don't forget to bleed the RABS valve, unless you previously bypassed it.
Old May 7, 2013 | 09:49 AM
garrettsr5's Avatar
garrettsr5
RABS valve?
Also I took the truck to class and after about 6 miles the pedal got hard and it had great stopping power :confused
Happened today and last night as well! WHAT THE HECK
Old May 7, 2013 | 08:57 PM
tecgod13's Avatar
tecgod13
RABS = rear antilock brake system
The RABS valve is mounted to the driver side frame rail under the front of the cab. There is a bleeder valve on it that needs to be bled after the rear axle.
Old May 8, 2013 | 08:04 AM
regidog's Avatar
regidog
Maybe check the vacuum readings coming from the vacuum pump (located on the top drivers side of the engine).
Old May 9, 2013 | 02:58 PM
Chevy_Eater
That's the A/C compressor, the vacuum pump is on the R/S, (passenger side), below the alternator.
Old May 9, 2013 | 04:15 PM
Phy's Avatar
Phy
On my '93 & '94, both w/o air con, the vacuum pump is on the top, towards the drivers side...
Old May 9, 2013 | 05:51 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
sorry for the hyjack guys.
Phy,your private messages quota is full.
Old May 9, 2013 | 05:53 PM
Chevy_Eater
Interesting, never ran into that. Then again, I don't know I've run into an IDI that wasn't factory with A/C.
Old May 9, 2013 | 06:00 PM
FORDF250HDXLT
was that a serp belt thing then? once they switched in mid '92,they placed the vac pump up top?
up top is where mine was (factory a/c) too.
Old May 9, 2013 | 06:01 PM
Chevy_Eater
That would make sense, my '92 was V-belt and all the accessories were traditionally located.
