I have a 97 f-350 diesel I had my trailer on and went to stop and the brake pedal was hard as a rock and was not stopping the truck.I went and got a master cylinder and put it on and still the same problem. I started home by the way it was a 4 hour trip and i would either have real soft pedal like full of air or rock hard pedal.Any Ideas? Thank You in advanced
I would pull the hose from the vacuum pump to the distribution manifold and check for vacuum there as well as the hose up to the booster before I bought a vacuum pump.
Its not turned any lights on.To me it acts like as long as you are above idle it has vacuum and the pedal is soft like air in the lines but once it idles there no vacuum and its hard as a rock.I did pull the hose off going to brake booster and it had very little pull on it.Thanks Mark
If you pump the brakes a couple times the light will come on from low vacuum if the pump is bad. I had a problem where the brakes were hard, and it turned out the be the booster.
