AOD Trans Help
Old May 5, 2013 | 10:46 AM
SVT Spencer's Avatar
SVT Spencer
AOD Trans Help
Hello guys, I have a 1985 F150 with a carbed 302 it once was a EFI 302. It has an AOD trans and it will not shift out of 2nd gear. The truck is 4x4 if that helps any. Anyone got any suggestions as to what might be causing this?
Old May 5, 2013 | 01:42 PM
Franklin2's Avatar
Franklin2
Since it's been converted, was the throttle rod or cable hooked up to the tranny? On this tranny this rod controls the shifting of the tranny. It can make the tranny have very soft early shifts which tend to burn it up, and it can also make the tranny have very late harsh shifts. It needs to be just right, and the geometry of the linkage needs to be correct so the tranny can read the throttle position and adjust itself.
Old May 5, 2013 | 11:30 PM
Cienega32's Avatar
Cienega32
Adjustment info if it helps:
Ford AOD Transmission
Old May 6, 2013 | 12:43 AM
Ken Blythen's Avatar
Ken Blythen
Are 1st & 2nd OK?
I hope this isn't your situation, but it's not uncommon for failing AOD's to first lose OD, then 3rd.
Old May 6, 2013 | 02:31 AM
joshofalltrades's Avatar
joshofalltrades
if it just has first and second, your tranny is on its way out. if you try to keep driving it how it is, make sure to have a AAA membership cause you'll probably need it to get home one of these days
your options are as follows, in order of price tag
1) junkyard tranny - pull the pan off and inspect before you pay for it, fine black dust and fine metal filings are normal, metal chunks mean bad tranny.
2) rebuild yours at home - if you have a transmission jack, an average set of tools, a good set of snap-ring pliers, average mechanical skills, and the courage to open it up, this is a valid option as long as no hard parts are damaged. you'll also need two work tables of decent size, as parts laid out in order can easily fill a 4x8 foot table, and you want a table you can work on without disturbing all your parts.
3) pay a local shop to rebuild or replace it
as franklin said, that linkage is absolutely critical to your transmission. driving without it has been reported to destroy a good transmission in 5 miles or less. but regardless of whether its at fault here, your transmission is damaged.
let us know what route you plan to take and we'll guide you through the process - unless you just pay someone to install one for you
joshofalltrades
double post
Old May 6, 2013 | 06:22 PM
Labhound's Avatar
Labhound
After my second used AOD, I said the heck with it and had it re-built at a local shop, it wasn't cheap....
Old May 6, 2013 | 08:05 PM
SVT Spencer
Originally Posted by Ken Blythen
Are 1st & 2nd OK?
First and second are fine, and I may end up rebuilding it myself, after I check the linkage and everything over and i know one thing the passing gear is not hooked up to the carb at all.
Old May 6, 2013 | 08:25 PM
Franklin2's Avatar
Franklin2
This tranny does not have a "passing gear" linkage like the other trannies. It has a linkage that is the tranny's lifeblood, and if it's not right it's had it.
Old May 7, 2013 | 02:29 AM
joshofalltrades
thats what killed it. as franklin said, that linkage isn't kickdown, its purpose is much like the vacuum can thingy on the back of a c6 - it controls hydraulic pressure inside the tranny, and is absolutely critical if you want the tranny to survive more than 10 miles.
as a result of this, i would guess that you've "simply" burned out some of the clutch packs in the tranny, and possibly had the dust from that plug up some fluid passages inside. so your rebuild will likely require all new friction surfaces, and a good cleaning of everything else. consider a new valve body, or at minimum open it up and clean it thoroughly, making sure not to lose or misplace the 2 or 3 ball bearings that live inside it, which can easily be lost after taking off its steel plate. i think there was another loose part in there too, so take pics along the way and be very aware for loose stuff like that.
this tranny is among the simplest ones to rebuild, but still be careful and precise about everything.
Old May 7, 2013 | 08:49 AM
Archion's Avatar
Archion
Veteran: Marine Corps
Your best and easiest bet at this point since the truck has been butchered would be to find a serviceable small block C6 and perform the swap to that. Much more user friendly and will likely be easier and cheaper than building the AOD and piecing all the proper setup to reattach the TV cable. It's a tougher trans. You will run higher RPM's on the hwy and get worse mileage, but with the carb swap worse MPG was inevitable anyway.
Old May 20, 2013 | 06:05 PM
SVT Spencer
What all would be needed for this swap and will a C6 bolt up to a 302
Old May 20, 2013 | 08:36 PM
Franklin2's Avatar
Franklin2
A c6 4x4 tranny is a very common tranny for these trucks and is easily found behind 302's, 300 sixes and 351w's, which would all fit behind your 302.
The c6 is cheaper to rebuild, and is a tough tranny. It's bad point is fuel mileage. If you are going to use this truck mostly local, and towing a lot with it, then I agree the c6 is your best option. If you travel long distances lightly loaded, you might consider how much it will cost to fix the AOD versus the gas savings.
8525ford
Dec 17, 2009 09:59 PM
mycam8u2
Apr 14, 2009 08:00 AM
85DougF150
Dec 4, 2007 08:25 AM
ANDEN
Oct 26, 2007 02:28 PM
VvDELLvV
Mar 13, 2005 07:22 PM
