1978 - 1996 Big Bronco
Heating up
Old Jun 6, 2003 | 07:16 PM
89Blk_XLT's Avatar
89Blk_XLT
Heating up
Hi all. First timer here. Just swapped my motor out in by 89 Bronco with a 302. Changed over to Mass Air and added a Crane cam to the long block. I just started it for the first time to do the break in and only ran it for about 5 to 10 minutes and the temp gauge went up high. Shut it off and noticed that engine was hot but the coolant line to the radiator were cool. What would be causing this condition? And also it will not idle. Has this something to do with the Mass Air or a vacum issue. All vacum lines are hooked up. Any ideas would be great. What to start to drive the "BRONC" after a couple weeks of driving a Focus. Little to small for me.
89Blk_Xlt
Old Jun 6, 2003 | 08:57 PM
mrwizard's Avatar
mrwizard
Heating up
Thermostat in backwards maybe?
Old Jun 7, 2003 | 01:08 AM
bigric's Avatar
bigric
Heating up
Did you install the lower intake? Perhaps the intake gaskets are not oriented correctly and the coolant flow is being blocked. If you received it as a long block, perhaps it's the thermostat as mrwizard suggested.
Old Jun 7, 2003 | 01:13 AM
alanscott's Avatar
alanscott
Heating up
Also, you could just be low on coolant. Remember to not add any while the engine is hot.
How is the oil pressure?
Old Jun 7, 2003 | 10:51 AM
89Blk_XLT's Avatar
89Blk_XLT
Heating up
Thanks for the answers. Checked the thermostat. It was in correct, spring towards the intake. I read in the manual that you are supposed to put the gasket on the intake first. I put it on the housing. Would that make the thermostat function improperly?
89Blk_Xlt
Old Jun 7, 2003 | 09:30 PM
bigric's Avatar
bigric
Heating up
Nope; just having the thermostat backwards would cause your problem. At least it was an easy fix!
Old Jun 7, 2003 | 10:29 PM
BOJOFASO's Avatar
BOJOFASO
Heating up
did you install the serpentine belt correctly? maybe if you didnt the pump and fan are spinning backwards
Old Jun 7, 2003 | 10:44 PM
89Blk_XLT's Avatar
89Blk_XLT
Heating up
Any easy ways to get the engine from being vapor locked. To much air into the engine block. Any easier way than just running the engine and forcing out? When checking the thermostat there was no coolant in the lower intake. Must have enough air that its not letting circulate. Anyone ever have this problem?
89Blk_Xlt
blk450er
Sep 15, 2016 12:35 PM
ManfredVonRichtofen
Apr 29, 2016 09:56 PM
masonandeers
19
Jan 5, 2016 03:25 PM
Ted's77
13
Aug 16, 2012 04:38 PM
lothar 2112
Nov 5, 2002 10:21 AM
