LED cab light questions
I have aftermarket lights installed on my 02 250 which are identical to factory lights.
I was looking at changing those to LED technology like the Recon or Atomic lights that still look like factory. Have read some bad reports on Recon's quality... would like to hear from anyone that replaced factory lights with LED cab lights...
Also, I like the looks of the Dodge cab lights. Just wondering since I have holes already in my roof, how far off these lights would be compared to the Ford lights and how many extra holes I would have to drill if anyone could comment...
Thanks a lot!
PC
middle 3 are those LEDs, outer 2 are just amber 194 bulbs
So, if you choose to go with Recon Dodge lights, I would recommend removing the sealant on the bottom to gain access to the lens cover screws, reseal the entire lens and base unit prior to installation and then try them.
I have had to pull 3 of them over the course of a few years to "reseal" them as they collect moisture and do not work.
As for the mounting, the recon dodge lights use 3 small sheet metal screws to secure them to the cab, and then one hole in the center of the triangle of the 3 for the wiring to pass through...if I initially had Ford style cab lights with the larger center hole I would have stayed with Ford lights and LED bulbs. Hope that helps.
