Stripped Bleeder Screw
Old May 3, 2013 | 06:54 PM
460 FORD MAN's Avatar
460 FORD MAN
I stripped my bleeder screw on the passenger front caliper. Any ideas how I can get it off now?
Old May 3, 2013 | 07:07 PM
co425's Avatar
co425
Stripped the hex head or the threads? If its the head try vice grips and a sharp rap with a hammer. If its the threads it would be easiest to replace the caliper.
Old May 3, 2013 | 07:43 PM
460 FORD MAN
It's the hex head. I tried vice grips and pb blaster but it still didn't budge. It's basically a round head now.
Old May 3, 2013 | 08:51 PM
Blue and White's Avatar
Blue and White
Its worth trying some gentle heat (propane) and another shot of PB blaster. Otherwise agree time for a new caliper.
Old May 3, 2013 | 09:26 PM
co425's Avatar
co425
I agree. Calipers are pretty cheap to fight them too much.
Old May 3, 2013 | 10:21 PM
Riderman's Avatar
Riderman
You can also beat on the next smaller size six point socket with a hammer on the bleeder. After you let it soak with your favorite penetrating oil as mentioned.
Old May 4, 2013 | 04:35 AM
Xauterus's Avatar
Xauterus
I think a replacement rebuilt exchange caliper would be the best idea. If the bleeder has frozen so tight it probably means that it has not been bled for a lot of years. So caliper is going to be full of muck.
Old May 4, 2013 | 07:58 AM
Filthy Beast's Avatar
Filthy Beast
If you can't get that bleeder off by working it back and forth, and a new caliper is out of the question for now, try bleeding it from the banjo bolt. Your brakes won't know the difference.
Old May 8, 2013 | 12:20 PM
wilcam47's Avatar
wilcam47
You could try using an easy-out /broken screw extractor tool.
Old May 8, 2013 | 12:42 PM
Sooper Camper's Avatar
Sooper Camper
i've yet to meet a broken/stripped bolt that couldn't be fixed by some heat and a bolt extractor.
Old May 8, 2013 | 01:17 PM
FordFanboy's Avatar
FordFanboy
Autozone will loan the bolt extractor.
stansrubyred2013
2009 - 2014 F150
Jul 2, 2019 06:59 AM
diesel-fitter-bum01
Jun 6, 2012 08:36 PM
Beanscoot
4 Cylinder Engines
Nov 6, 2008 01:02 AM
wiccantoy
Mar 29, 2008 07:34 PM
NMCam
Jun 5, 2002 08:28 PM
