Kickdown Cable Install Help..lost
Old May 3, 2013 | 10:49 AM
SC'79's Avatar
SC'79
I have a kickdown cable that i'm trying to install on my 1979 f150 with a 460 and c6, however the original kickdown rod is not connected to the carb, but is there. It doesnt reach or i would just use the rod. This is the cable:
I need to know where 1,2, 3 go. 4 goes where the kickdown rod attaches to tranny. 1 goes on carb linkage, but not sure where, ( Edelbrock 1411) pictured here:
You can see the original kickdown rod behind the linkage a few inches shy.
Thanks for any guidance and help
Old May 3, 2013 | 11:06 AM
sloopy76's Avatar
sloopy76
Well I'll be honest I've never seen a kickdown cable before but as for your rod being too short I Edelbrock makes an "Automatic Trans. Rod Extension Kit for Ford" part # 8011. Hope this helps.
Old May 3, 2013 | 11:10 AM
SC'79's Avatar
SC'79
it seems as though I have extra linkage on the carb that I can take off? and I dont have the spring return bracket as pictured in the manual? I have a spring return in front of the linkage instead of behind, and the throttle cable does not have a way to connect to the kickdown adjuster bracket.
Been looking at this: http://www.lokar.com/downloads/pdf-i...ford-c6-kd.pdf
Old May 3, 2013 | 09:56 PM
MeanGreen460's Avatar
MeanGreen460
why don't you just lengthen the original kickdown rod
Old May 3, 2013 | 10:48 PM
grinnergetter's Avatar
grinnergetter
There are several threads with pics regarding this problem. Using the advanced search should yield a ton of info.
Old May 4, 2013 | 08:38 AM
460me's Avatar
460me
Here a pic of my on a 460(Lokar kick down cable)
Old May 4, 2013 | 08:40 AM
SC'79's Avatar
SC'79
Okay, so I am missing the carb bracket shown in your picture 460me, however, I have extra linkage on my carb that you do not have, So I am wondering where I can connect it? Or should I just take the extra linkage off? See my pictures for reference. Thanks
xeroshi
Jun 19, 2015 01:18 PM
tallinboy
Sep 23, 2010 11:55 PM
85 Stepside
24
Oct 12, 2009 10:54 PM
JonF250
Oct 10, 2007 07:41 AM
stanz
Oct 12, 2004 05:45 PM
