NP435 swap
Old May 2, 2013 | 08:37 PM
Cdouglas18's Avatar
Cdouglas18
NP435 swap
I recently bought a 1964 F250. The previous owner swapped in a 360 with an NP435. I've had it for only a couple months and it's been great, but I just lost 2nd and 3rd gear. As much as I like the np435 I top out at about 45mph, so I'd like to swap it for something that will provide a bit more drivability. Any suggestions? I should add that the rear end is spicer/Dana 4.10 and I plan on doing a bit of heavy towing. Any tips or input would be great. Thanks guys!
Old May 2, 2013 | 09:26 PM
1972RedNeck's Avatar
1972RedNeck
How do you top out at 45? My truck with 4.10's and the 435 will go 90.
Old May 2, 2013 | 09:45 PM
Cdouglas18's Avatar
Cdouglas18
Hmm that's a good question then. There's no tach but but the rpms past 45 are really high.. If I really push it I might get 50, but it's maxed there.
I wouldn't be opposed to rebuilding the 435 if I could get a decent highway speed.
Old May 2, 2013 | 09:56 PM
garbz2's Avatar
garbz2
Unless you install an overdrive the NP is a 1 to 1 final drive like all other non OD units.
Garbz
Old May 2, 2013 | 11:02 PM
SuperSabre's Avatar
SuperSabre
Since you're talking about a nearly 50 year old truck which no longer has its original engine, maybe the differential gears were also swapped out to, say, 4.56s? Are you sure your speedo is accurate? Tachs don't cost much and are easy to hook up - then you'll know what you're really turning. Someone may correct me, but I think stock 360 2 bbls are pretty much done winding by about 4800 - 5000. Too bad you don't live in Arizona - I have a surplus NP435 available. Good luck!
Old May 3, 2013 | 07:06 AM
1972RedNeck
And if you wind them that high in 4th with 4.10's you'll be over 100.
Old May 3, 2013 | 08:51 AM
Cdouglas18's Avatar
Cdouglas18
So if the rebuild doesn't solve the prob then there is another issue that ill need to address regardless of which trans I have in there.
Thanks for all the quick responses I appreciate the help
Chad
Old May 3, 2013 | 09:40 PM
110's Avatar
110
why would it ruin the mileage? im new at this and have no idea what im doing. but i also have am np 435 that id like to put a tremec 5 speed in its place. however i dont know what gears ive got. theres no id plate on my diff that i can find. and i have a 390 in it and no tach but it sounds high rpms above 45.
Old May 3, 2013 | 09:45 PM
110's Avatar
110
sorry that was the wrong post
Old May 3, 2013 | 10:57 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
AXLE code stamped on the Warranty Plate, located on left door face below the latch.
F100 9" ID tag located at approx. 5 o'clock under one of the bolts that retains carrier to housing.
Old May 3, 2013 | 11:03 PM
110's Avatar
110
Thanks ND!
Old Jan 22, 2014 | 07:53 AM
Cdouglas18's Avatar
Cdouglas18
Thanks for everyone's input on the 435. I know it's been awhile now but I wanted to give some resolution. I ended up rebuilding the np435 I had. The synchro was dust- literally pulverized like mud in the bottom of the trans. The problem with the high rpms at low speed was a problem with the transfer case. I was able to move the shifter but it was never actually coming out of 4 low.
Thanks for all the help
Old Jan 22, 2014 | 09:20 PM
swann79's Avatar
swann79
Problem solved = happy guy driving a happy truck!
Howard1990
May 20, 2019 10:54 AM
Kriswat33
Apr 27, 2017 04:33 PM
AbandonedBronco
31
May 3, 2012 10:06 AM
iskerbibel
16
Jan 20, 2005 12:31 AM
