Carb size ?
May 2, 2013 | 10:07 AM
Carb size ?
I have a 79 150. 460 .060 over. Rv cam stealth intake. Is the 600cfm Edelbrock good enough for this or should it have something bigger on it?
May 2, 2013 | 11:05 AM
It will run it but it's going to be a little bit small for the motor. I'd have something in the 700 or a 750 range on it.
May 2, 2013 | 11:30 AM
Yeah. I kindof thought that with some of my research. Do you think Holley or Edelbrock? I'm somewhat of a novice, but Holley s scare me a bit because of the backfire and power valve deal if I remember correctly
May 2, 2013 | 02:18 PM
mostly the power valves have backfire protection on them now. biggest problem with the holley's is leaking.
Either will work just fine.
May 2, 2013 | 05:20 PM
I have a 600cfm on my 466. I plan to get a 750cfm sometime.
May 2, 2013 | 09:22 PM
Edelbrock it is! Again let me mention that I'm a novice. But what is the difference between vacuum secondaries and mechanical secondaries?
May 2, 2013 | 11:10 PM
ironhead86
31
Apr 6, 2011 07:31 PM
7mpg302
Dec 4, 2008 04:13 PM
dieselburner6.0
Apr 25, 2007 12:08 PM
dakota_viking
Jun 16, 2005 09:57 PM
ford390gashog
Aug 31, 2004 08:40 AM
