I am having issues with the new truck. Research shows Ford has been having this problem for some time now with no fix is sight other than they know about it.
Have you heard of a F150, 6.5' bed, vibrating, when taking off from a standstill when the bed is loaded with 200lbs or more?
It almost feels like when your are in 4whdr on dry payment and try to make a turn.
Goes away after reaching 10mph
I know that I have read some complaints about that in the forums here and if I remember correctly it has something to do with the slip yoke (sp?) I do not remeber seeing any permanent fix to the issue.
Your truck has a 6.5' bed along with it being a crew cab???? Damn, that thing is loooong.
It is a drive shaft problem.
I talked to some of the guys out back...as you mentioned...Ford knows about it...but...they don't have a fix.
