Delaware Chapter Join Chapter, Leader:
DE May chat thread
Old May 24, 2013 | 10:38 AM
  #436
tiny1's Avatar
tiny1
Moderator & CL
Ahhh, I did not see the glow due to the overcast rainy conditions that we are having and thank you for sharing the eye bleach.
Old May 24, 2013 | 10:39 AM
  #437
dustybumpers's Avatar
dustybumpers
Yeah, raining and miserable here too. I barely got the blades on the belly mower before it busted loose.
Old May 24, 2013 | 10:52 AM
  #438
tiny1's Avatar
tiny1
Moderator & CL
Well it looks like it is trying to clear up here. I need to figure out what is wrong with my Cub lawn tractor as to why is will not start. My lawn is getting a little on the loooooooong side.
Old May 24, 2013 | 10:56 AM
  #439
67nukeford's Avatar
67nukeford
Veteran: Navy
Neil, you can borrow some of mine.....
Old May 24, 2013 | 11:19 AM
  #440
dustybumpers
could be fuse on the solenoid, you have to open the plate under the steering wheel on my Murray.
Second problem I run into, the switch under the seat wears out after a while.
Old May 24, 2013 | 11:26 AM
  #441
CLINT-THE-GREAT's Avatar
CLINT-THE-GREAT
Posting Legend
Hey George! It's finally Friday!! Let the Long Weekend BEGIN!!!!!
-The Great
Old May 24, 2013 | 12:36 PM
  #442
tiny1's Avatar
tiny1
Moderator & CL
If it was the switch under the seat, it would not even crank. I am hoping to dig out the schematics on it tonight to try and figure out what it may be. The dealer stated that they have seen several cases where the ethanol in the gas that we have has damaged the rubber seals and gaskets in the carb. I did also notice that the foam pre filter was missing some very large chunks and there was no evidence of it under the air cleaner cover. I am wondering if I had some mice under the hood this winter and they caused some damage to the wiring.
Old May 24, 2013 | 12:45 PM
  #443
67nukeford's Avatar
67nukeford
Veteran: Navy
Neil, I've heard that you shouldn't use ethanol in mowers/ tractors.
Old May 24, 2013 | 01:22 PM
  #444
tiny1's Avatar
tiny1
Moderator & CL
Well all of our gas "may contain 10% ethanol" and I have not seen any of the local station sell any that does not contain it.
Old May 24, 2013 | 01:32 PM
  #445
67nukeford's Avatar
67nukeford
Veteran: Navy
There is usually one pump at our stations without it.
Old May 24, 2013 | 02:07 PM
  #446
tiny1's Avatar
tiny1
Moderator & CL
Not here
Old May 24, 2013 | 02:29 PM
  #447
dustybumpers
Same here Obama gas........
Old May 24, 2013 | 02:31 PM
  #448
67nukeford's Avatar
67nukeford
Veteran: Navy
Hey Charlie, what's happenin?
Old May 24, 2013 | 02:32 PM
  #449
dustybumpers
Not much. Raining and cold here.... wood stove is cranking
Old May 24, 2013 | 02:40 PM
  #450
67nukeford's Avatar
67nukeford
Veteran: Navy
Nice here, sunny and 70 or so. Storms might move in tonight, though.
