Blown engine or failed injector? -- need help
Old May 5, 2013 | 11:40 AM
cowmilker08's Avatar
cowmilker08
Originally Posted by madpogue
Did you pull fuse #22, or in some other way disable the injectors, for the test? You can also crank the starter by running a jumper wire from the battery + to the small terminal on the starter relay, without even having the key in (be SURE you're not in gear!).
If you have a good tester, it should go up with every stroke, about 8-10 times, then level off, and shouldn't go down in between until press the release button on the tester. You shouldn't have to be watching the needle while you're cranking the engine.
Yes, the fact that they all registered something is good news, but it sounds like the real take-away is that you need to get that tester working better.
I had to use a straight test pressure gauge since the kit I borrowed from a friend only went to 300 psi. I called all the parts stores in town, but none have a tester for these high pressures.
I had all the UVCH's laying on the bench and disconnected the huge engine harness connector to get it out of the way, so the #7 injector should not have been spraying fuel, especially that much.
Originally Posted by oldbird1965
Did all the rockers look good? Any possibility of a bend push rod? How does the anti freeze look.
The rockers look good. No obvioulsy bent push rods either but I didn't remove them. It may be a good idea since I will be waiting for injectors anyway. How do you remove and re-install them correctly.
I will take a look at the anti-freeze and report what I find.
Old May 5, 2013 | 12:10 PM
oldbird1965's Avatar
oldbird1965
There is a write up in the stickies on injector install.
Old May 5, 2013 | 02:49 PM
cowmilker08
I meant the push rods.
Old May 5, 2013 | 03:00 PM
444dieselrod's Avatar
444dieselrod
Just unbolt the rocker assembly and take them out, its pretty straight forward.
Diesel Rod
Old May 5, 2013 | 03:05 PM
cowmilker08
What about re-installing? Whats the torque spec?
Old May 5, 2013 | 03:20 PM
cowmilker08
I took a sample of the antifreeze through the drain **** in the radiator. Below is a picture. It looks kinda brown. I couldn't find a compression tester gauge that shows maximum PSI that is rated for 400 psi so I worked on my simple gauge and had my father in law watch it as I cranked the motor over.
The numbers were consistent between cylinders today, but still low. I decided that since they were all giving about the same results that I didn't really need accurate numbers at this time. So I moved on.
I pulled the injectors and found that my past dumba$$ mistake has caught up to me. The second picture is how about half the injectors looked when I pulled them out. A year and a half ago I put new external rings on and didn't have a small enough torque wrench so I guessed at it. BIG MISTAKE. The hold down bolts on some of them had worked loose.
#7 seven luckily did not have a busted off tip! Who-hoo! But the lower most o-ring was almost cut in half and the lower portion of the injector looked about like the one in the picture.
Could the torn ring have been the problem or it is still an internal problem in the injector? Either way I will be sending them to Rosewood. As far as I know they are original injectors just shy of 280k miles.
Old May 5, 2013 | 04:46 PM
444dieselrod
That injector is pretty dirty on the end, it looks like it was leaking combustion gasses past the copper washer on the bottom.
A cut o-ring could cause the problems you had but I would think it would set a CEL in the process.
Diesel Rod
Old May 5, 2013 | 10:50 PM
cowmilker08
There was no CEL when it happened but it working because it came on when i turned over the engine without having the harness plugged in.
Old May 28, 2013 | 12:34 PM
cowmilker08
I got my rebuilt/upgraded stage I's from Rosewood on Friday, a new intake boot and SD VC gaskets and harnesses from Riffraff. I also did the "Perlich mod" (atleast that what my friend calls it since I'm probably the only one to ever do it, but thats a different story.)
I got 'ol Great White started up Sunday evening, and then finished buttoning everything up Monday afternoon in the stinking rain. She is running like a Champ now. I cannot believe how smooth it pulls through the rpms. It used to be pretty shaky in the 1000-1500 rpm range. Also it feel like it actually has some power now, but the roads have been wet so evertime I push it a little I just spin the wheels (which is more than I could say before).
Thanks to everyone, including Jim and Clay, for all the help. Now I just need a chip!!
Old May 28, 2013 | 02:37 PM
oldbird1965
I need, need and want! LOL Glad you got her going.
FL SuperDuty
Mar 13, 2019 09:44 PM
puffen:D
30
Sep 20, 2014 01:16 PM
largefries
Sep 17, 2012 09:50 PM
Toreador_Diesel
17
Mar 31, 2011 04:55 PM
sean23johnson
May 26, 2005 09:00 PM
