Odd OBDII Behavior
Old Apr 30, 2013 | 04:07 PM
bishop13's Avatar
bishop13
Odd OBDII Behavior
I was trying to get my 03 X 6.0 Powerstroke smogged this morning and the darnedest thing happened, their machine couldn't communicate with the truck. This is weird because I have a Scangauge II hooked up full time to the same OBD II port and it reads just fine. My cheapo scanner also connected with no problems. I checked out the fuses and for gunk in the connectors, but no dice. Has anyone else experienced something similar?
Old Apr 30, 2013 | 10:46 PM
Stewart_H's Avatar
Stewart_H
Moved to the 6.0L PSD forum.
Stewart
Old May 1, 2013 | 11:07 AM
dannyboy950's Avatar
dannyboy950
Check for a bent pin on the scanner plug. I have one of my scanners that a pin will sometimes get bent and not go in the slot of the connector on the truck.
Old May 1, 2013 | 12:23 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
If your scanner and SGII hooks to it, the state has a problem with their devise.
Old May 1, 2013 | 12:35 PM
bishop13's Avatar
bishop13
This bloody state has a problem with *everything*, so I wouldn't be surprised.
Old May 1, 2013 | 09:42 PM
Mich6.0's Avatar
Mich6.0
THANK YOU C.A.R.B., TIME TO MOVE OUT.
Old May 2, 2013 | 06:24 PM
cheezit's Avatar
cheezit
wont be the first time this has happened either, im not surprised. and this is more then likly your concern
Old May 2, 2013 | 07:56 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Go try a different inspection station.
6.0techwannabe
23
Jan 2, 2020 04:06 PM
tenwheeljoe
Oct 12, 2016 06:58 PM
Jnas860
Oct 11, 2013 07:29 AM
77300i6
1983 - 2012 Ranger & B-Series
Oct 15, 2007 08:55 AM
