flareside bed protection options
Old Apr 30, 2013 | 03:29 PM
nikmish's Avatar
nikmish
I need you help finding an option to protect freshly restored bed on my truck.
What would one have to use the truck as a truck and move debris and dirt for home remodeling projects.
I spend to much time and money to get to this point, so I must do something to keep it looking nice as long as possible.
Old Apr 30, 2013 | 03:58 PM
JayzDaddy's Avatar
JayzDaddy
Your funny. If my bed looked like that i would make a polyethylene vacuum molded see through protector so rain couldnt even touch it.
In all honesty if i took one that far id just buy a trailer.
Old Apr 30, 2013 | 04:37 PM
nikmish's Avatar
nikmish
Trailer is not an option - no place to store it
Yes, I got carried away with this one...
Old Apr 30, 2013 | 04:51 PM
Labhound's Avatar
Labhound
Maybe lay a large moving blanket down and use a tarp over it?
Old Apr 30, 2013 | 09:02 PM
dohc_chump's Avatar
dohc_chump
This space for rent...
What about making something out of plexiglass that fits in the bed?
Old Apr 30, 2013 | 11:14 PM
nikmish's Avatar
nikmish
I would like to protect not only wood but sides and tailgate too.
Thinking of moving blankets plus tarp and ask wife to saw it such way that it will be easy to "wear" when needed.
Old May 1, 2013 | 08:30 AM
1986F150six's Avatar
1986F150six
Beautifully finished!
Since storage is a problem, what about borrowing or renting a trailer or renting a truck for those few times needed for doing "dirty" work?
Old May 1, 2013 | 12:53 PM
nikmish's Avatar
nikmish
I'm DIYer and I hove a lot of projects around our 'fixer-upper' house and tight budget. Renting something will mean extra $$...
Any more ideas on removable liner or something similar? There are not much for flareside out there.
Old May 1, 2013 | 03:28 PM
mudgepondexpress's Avatar
mudgepondexpress
Cut down a rubber bed mat. You could get one for a long bed and have it roll up the front and back for protection. It would be wide everywhere but the wheelwells and if cut right would roll up the side a 10" or so.
Kenny
Old May 2, 2013 | 09:58 AM
1986F150six
What about a large flat sheet of heavy cardboard, such as part of a shipping container. Cut it to fit allowing extra to protect the front and sides as well as the inside of the tailgate. You could duct tape the seams and then throw away after use or when badly worn. Cost effective!
Old May 2, 2013 | 09:37 PM
Ford F834's Avatar
Ford F834
I would build a plywood box and line the ~outside with commercial carpet (the glue-on kind). Fasten the box in the corners with 2x lumber and wood screws so it could be broken down quickly and easily for compact storage. The single wall steel on those beds is so easy to dent that tarps and such won't protect it. Only way I can see working is a rigid wooden insert that is padded with carpet to prevent scratching from debris that works its way in between the bed and the liner. I like the rubber bed matt idea too, but it won't help your sides and tailgate. Gorgeous restoration by the way.
Old May 3, 2013 | 09:35 AM
80FlareSide's Avatar
80FlareSide
I intend to be restoring the bed on my truck next winter and have similar concerns. The best idea that I have been able to come up with is as follows:
1 - Install Airline track mounting points along the top edge of the bedside (front, middle, rear) and one at the top center of the front bed panel.
Then I plan to uses these studs:
as mounting points for a custom cut and fitted heavy canvas tarp / bedliner.
So long as there are grommeted holes in the liner, it can be held to the stud with an eyebolt & lock-nut. The eyebolt can then be used as a tie-down.
Old May 3, 2013 | 10:57 AM
nikmish's Avatar
nikmish
Very interesting!
Where can I find all this?
Old May 3, 2013 | 10:59 AM
nikmish's Avatar
nikmish
never mind, I checked image location: Ratchet Straps, Tie Down Straps, E Track Tie Downs, Cargo Straps - U.S. Cargo Control
Thank you!
Old May 3, 2013 | 06:17 PM
garthneddy's Avatar
garthneddy
Maybe you could recreate the inner bed panels and floor from diamond plate. If you bent the sides over to mimick the factory bed rails they could just hang off the bedsides. Throw some type of protective material on the backside to protect your beautiful paint and woodwork, and with it being aluminum it would be a breeze for any man or woman to remove by themselves.
Serni02
Sep 1, 2017 10:27 PM
South of BC
Jun 6, 2015 08:03 AM
GwarForAll1021
2010 - 2014 Ford SVT F150 Raptor
27
Jul 21, 2014 08:11 AM
impalaslayer
34
Feb 18, 2011 11:43 PM
bucks77ford
15
Mar 13, 2007 12:36 PM
