Modular V10 (6.8l)
Piston Slap??
Old Apr 30, 2013 | 12:07 PM
jerem0621's Avatar
jerem0621
Piston Slap??
Occassionaly I have a slight knock on start up with my V10.
It doesn't sound like a rod knocking or like an exhaust leak.. is this piston slap the early V10's are famous for?
Should I do anything different? I run standard 5w20 motocraft blend.
Thanks!
Old Apr 30, 2013 | 12:57 PM
Wolfboro's Avatar
Wolfboro
Also ,use Motocraft oil-filter (or equivalent) which has a silicon anti-drain valve . It should help with start-ups.
Old Apr 30, 2013 | 04:26 PM
cole1996's Avatar
cole1996
Does it sound like the cooling fan starting? My truck and my moms E-350 occasionally make a knock sound on startup after its been sitting awhile.
Old Apr 30, 2013 | 05:13 PM
jerem0621's Avatar
jerem0621
It not a cooling fan. It may be broken exhaust manifold studs?? It just doesn't sound like any exhaust leak I have ever heard.
After the truck is warm it goes away and is so quiet you can hardly hear the vehicle running.
I realized that my last oil change I used Mobile 5000 5w20. It's time for another oil change. Maybe the Motocraft 5w20 will resolve it. I always used the Motocraft filter.
Old Apr 30, 2013 | 06:39 PM
cole1996's Avatar
cole1996
I've used Fram filters and mobile1 oil for as long as I remember. No piston slap. Always runs like a champ!
Old May 1, 2013 | 12:04 PM
dkf's Avatar
dkf
Short skirt hypereutectic piston with a long stroke tend to have some piston slap on startup. Mainly startup in colder temps. I have some in colder temps and I use MC Filters and 5w-30 synthetic. Switching to a different brand oil more than likely will not change anything. Fram is an inferior filter (even the more expensive versions) best bang for the buck is the MC FL-820s or Purolator Pure One equivelent.
C.W
Modular V10 (6.8l)
Jan 8, 2015 07:19 PM
jerem0621
Modular V10 (6.8l)
Jan 1, 2013 01:44 AM
mizzitch
Modular V10 (6.8l)
25
Dec 23, 2005 09:48 PM
4.9LFord
Mar 11, 2005 12:41 PM
