of late I've been lacking with traction. i have been stuck in the mud 5 times in the last week. and it will just be on top of the ground. i have Firestone destination AT 285/75/16E tires, they have good tread left. when i get stuck only 1 tire will spin, and the truck has a positive rear end. what can i do to help this? most of the time all i takes is a small pull and im good, Saturday i backed a trailer up unloaded then could not move an inch. what is the problem tires rear end?
How is the front pulling? I know my dads 2x4 would get stuck in mud very easily, with only one wheel pulling. since I've had a 4x4, I haven't had any issues getting stuck, but that's in sand and not mud. I can bury the rear end, and still get out if I lock it in. I feel my diff jumping back and forth very often though.
Iirc the true trac is a limited slip. It won't do much better than the oe in mud. You will want a selectable locker. Once it is engaged both tires will spin at the same rate. You could also just air down the tires and feather the parking brake. That will preload the ls diff and help transfer the power to the tire with traction. Of course you will need to fully reinflate the tires before you pull a trailer. When in mud, wheel speed is your friend
If only one tire is spinning you do not have a posi. I would go with a trutrack if I was you that was it is an open diff until it senses slippage then it will lock both axles in. I would also have a shop put it in
If your in the mud that often ditch the A/Ts like said above A/Ts are mostly a street tire anyways.
A true trac is a gear driven torque splitting diff that basically had a bias range geared into it. No clutches or springs. They work about as well as anything short of a full on selectable locker
I have the same problem but in snow and ice as Snakedoc. My 2002 f350 4x4 according to the code on the diff. plate shows it is a limited slip diff. Well, I got stuck in my driveway in about 2 in. of snow/ice. One front wheel spinning and ONE rear wheel spinning. My wife in her Subaru just calmly drove around me and laughed. I love the truck but it has horrible traction in snow/ice.
ARB air locker. Had one in the rear end of my 78 bronco. Awsome traction. The problem with a Detroit locker is when on icy roads it can be,shall we say, stressfull, especially when she breaks loose.
You can buy what us jeep guys refer to as a "lunchbox" locker that replaces the spider gears with a ratchet mechanism. However while easy to install they can be less than smooth on the street
after watching this video i didnt think it would be to bad but it is also on a suburban so i dont know if theres a huge difference in installation. I to have the same problem when not in 4x4 so i have been looking into them a little bit.
i would love to have a set of mud tires but they dont last and i tow all the time.
i have a winch that is great in helping me out,
i just dont know if my diff is bad, but the code says it is limited. the front dose the same only 1 wheel spins when stuck?
A lot of LS differentials out there will act like an open when tired or too much friction modifier is added. When installing a 08 diff cover on mine I was careful to add only a bit of the friction modifier at a time, sneaking up on the sweet spot where the LS actually works. If yours is not terribly worn that strategy can work for you. If you have a tree sprouting money out on the back 40 I'd go with the Detroit TrueTrac. ARB air locker is overkill for your application, which sounds a lot like mine. But for now Shanejet has it right, air down and apply a little parking brake to control the spin. It's a technique some people master and they make it look easy, but I kinda suck at it.
