Shaved drip rails?
Old Jul 12, 2013 | 10:14 AM
HIO Silver's Avatar
HIO Silver
Originally Posted by 78_f800crewcab4x4
I will just throw in my useless opinion:
If your truck has nice drip rails and a nice roof skin, please don't go slicing off your rails. Welding the entire length of the roof panel scares even me as I HATE plastic filler. if you do this mod, please understand that you WILL warp the roof and you CANNOT hammer-and-dolly this area to remove welding shrinkage. You cannot eliminate warping shrinkage by just spot welding a little at a time. when the weld cools, the metal shrinks, period. If your roof is a mess already, by all means, cut away!
By the way, all of you that think that rust starts on the outside of the roof from rain running down the side are 3/4 incorrect. The damp condensation that beads up on the inside of your roof in the mornings when the dew point is reached, collects under your roof skin where the structure/drip rail/skin pinch weld is, is why you get rust holes. Recommend replacing weather strip.
Not useless at all!! I too observed the phenomenon when my 73's headliner warped into oblivion. The ideal solution is to fully insulate the roof cavities and panels... all the way down to the where it is generally inaccessible.
Old Jul 15, 2013 | 07:29 PM
juchertf100's Avatar
juchertf100
so after alot of thought and inspecting ive decided to not shave them they are in almost perfect shape,althow i like the shaved look im keeping them i can spend the time elseware.
Old Jul 16, 2013 | 02:32 PM
Scot's Avatar
Scot
The drip rail in most places is 3 layers thick. Cut a short section off and weld to keep things from getting to out of shape.
A possible drip rail donor is mid to late '70's GM pickups. The drip rail is screwed to the cab. The angle where it goes behind the door is different so it would have to be re-bent.
2beast
Large Truck
Apr 10, 2016 04:19 PM
Steve Christensen
1947 and Older Ford Trucks
Jul 26, 2015 12:56 AM
ryans88gt
Nov 18, 2014 08:15 PM
caprisecca
Aug 6, 2013 10:53 AM
