quick question on E40D
Old Apr 29, 2013 | 03:47 PM
Bill97's Avatar
Bill97
Found a crew cab that I may pick up. Is an E40D transferable between a regular cab and crew cab? I assume they are, but want to make sure. Mine is starting to go, and would want to swap trans so I could sell mine, and put a built one in the crew cab.
Old Apr 29, 2013 | 04:17 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
There is no difference in the transmission between any of the cab styles or wheelbases. There is only a difference between 4x4 and 4x2, and between diesel and gas engines.
Old Apr 29, 2013 | 04:45 PM
Bill97's Avatar
Bill97
Thank you! Also - if my trans was rebuilt 25K miles ago, and operates fine under easy acceleration, but bangs around a bit under hard acceleration in 1st gear, is there any way that I can get the trans shop to do a inexpensive fix to buy time, or is that a complete rebuild scenario?
Old Apr 29, 2013 | 09:42 PM
Mark Kovalsky
Yes, that can probably be repaired without a rebuild.
Gaige0715
1961 - 1963 F100 Unibody
Apr 21, 2018 11:00 PM
tootsie
Jan 13, 2011 03:45 PM
harpmatt
Feb 13, 2000 10:01 PM
