Fender mounted starter relay
Old Apr 29, 2013 | 11:13 AM
96ford250's Avatar
96ford250
How many wires go to the starter relay? I have a ton going to mine and I have stuff in my cab that won't turn off and I think I have a ground hooked to mine that's back feeding any help would be greatly appreciated.
Old Apr 29, 2013 | 11:26 AM
madpogue's Avatar
madpogue
Pretty-much everything in the truck connects to the battery via the starter relay. But it's only using that terminal as a junction point; the relay itself is not part of the circuit. What in particular isn't turning off? Do you mean you have accessories that should only go on with the key in ACC or RUN, and they go on without the key? That's more likely a problem with the ignition switch.
Old Apr 29, 2013 | 12:03 PM
96ford250's Avatar
96ford250
The abs light, the battery light is on but very dim, and the radio is on but it won't do anything when the key is on or off and when i remove it. That's why I think there's a ground on the power side.
96ford250's Avatar
96ford250
It's really confusing
Old Apr 29, 2013 | 12:50 PM
Hussler's Avatar
Hussler
Probably not a lot of help but here is a picture of mine. Terminal unplugged is the key to start wire. Big back terminal goes to starter relay. Big front terminal is battery, glow plug relay, alternator and main power to fuse boxes.
Old Apr 29, 2013 | 04:30 PM
96ford250's Avatar
96ford250
This is really making me think my starting relay is fried ill have to test it tonight and see what I get I have no crank and I got this back feeding problem I think it's either the relay or the ignition switch
Old Apr 29, 2013 | 04:36 PM
Hussler's Avatar
Hussler
In the picture above you can see where I have the ignition switch (start) wire unplugged. If you take a jumper wire and jump the bolt looking connector to the plus side of the battery the relay will engage and crank the truck. BE SURE the truck is in park or neutral with brake ON because this procedure bypasses all safety switches. Best to stand to the side just to make sure.
Old Apr 29, 2013 | 06:18 PM
96ford250's Avatar
96ford250
It starts just fine I replaced the ignition switch and I do have functions on the radio but the abs light and the radio doesn't turn off and still no crank
Old Apr 29, 2013 | 06:53 PM
96ford250's Avatar
96ford250
When I try to crank it my IDM relay clicks over and over? I do not have an IDM in the truck do I need one for it to crank
Old Apr 29, 2013 | 08:38 PM
madpogue's Avatar
madpogue
Have you load tested both batteries, in isolation from one another? Have you tried to crank the engine by hand?
Starting system does not depend on the IDM or PCM.
Old Apr 30, 2013 | 04:49 PM
96ford250's Avatar
96ford250
I figured it out!! The key cylinder was out of time with the ignition switch what a pita
AMGrulz
Nov 16, 2014 09:51 AM
Explorer220K
Jan 31, 2011 06:36 AM
carls150
1997 - 2003 F150
Dec 30, 2010 04:17 PM
robbyf250
Aug 16, 2010 10:18 PM
melvinhil
May 23, 2006 07:15 AM
