What could it be
Old Apr 28, 2013 | 11:29 PM
Boodrow379's Avatar
Boodrow379
What could it be
Well I've gone through two differant rebuilt carbs, my truck starts fine now compared to it wouldnt start at all before, it will idle fine for you to set timing, etc, tap the accelerater in neutral and it pops and dies, not quite a backfire just pops and thats it. Messed with the jets, idle and that stuff. New fuel pump, lines, clean tank, new distrubuter, plugs, points, wires everything gaped, good gas. Ive rebuilt probably 70 or 80 percent of this truck and just getting so frustrated i think im getting ready to tear it apart and sell whatever parts I can
Old Apr 28, 2013 | 11:45 PM
Phantomtruck68's Avatar
Phantomtruck68
Sounds like accelerator pump on carb is not working properly. with engine off look down carb and move throttle you should see two solid streams of gas in the throat of carb just below choke plate. If not a solid stream of fuel then the diaphram make be bad or the passages are clogged.
Old Apr 29, 2013 | 07:26 PM
JEFFFAFA's Avatar
JEFFFAFA
I agree. Sounds like the idle curcuit has fuel but not the other curcuits. If this is a holley it sounds like the metering plate that the jets screw in to has some crap in it. The two plugs on the top of it would have to be removed to totaly clean it out. BTW, they were rebuilt by who?? A qualified shop with real carb soak?
Old May 2, 2013 | 11:12 PM
Boodrow379's Avatar
Boodrow379
They were both motorcraft and they spray fuel into the throats if I look down. The carbs were rebuilt in town by a guy that rebuilds trucks like these.. he knows what hes doing but im starting to think its not the carb. I went out and tried to start it today and now it wont
Old May 3, 2013 | 12:08 PM
CougarJohn's Avatar
CougarJohn
It idles well so it sounds like there are no vacuum leaks. You know what you are doing with the carb and of course the choke is set properly. The problem might be the distributor plate and vacuum advance.
Try this: Pull the vacuum advance line to the distributor and plug it at the carb. Dry the plugs, get it started and idling. Punch it. Normally this sharp drop in vacuum jerks the plate. Bad bushings or something screwy with the diaphram can misalign points and maybe cause your problem. If the problem goes away, replace the advance unit or better yet the distributor.
It is worth a try.
Don't quit yet. There is one simple thing that is causing your problem. You haven't found it yet but you will.
Semper Fi
Old May 3, 2013 | 01:33 PM
JEFFFAFA's Avatar
JEFFFAFA
The popping is from a lean mixture when you crack the throttle but no extra gas coming from the carb to compensate as usual. I think it is bad fuel pump. By chance is it a NAPA brand one you installed? In the last week or two I have seen 3 or 4 guys having trouble with replacement fuel pumps on this forum. All of them NAPA. Including my own Bump. Check you engine dipstick and see if any gas in the oil pan.
Old May 3, 2013 | 05:52 PM
CougarJohn's Avatar
CougarJohn
Jeffa may be right. Popping is lean but also bad ignition.
If you have gasoline peeing down the carb throat at it will not start, you have probably wetted the plugs with gasoline.
Do what I said: Pull the vacuum line at the distributor and plug it with a #10 machine screw. Dry the plugs with a torch, replace them, and it will fire.
Old May 3, 2013 | 11:24 PM
Boodrow379's Avatar
Boodrow379
It is worth a try.
Semper Fi
Ok I will try that tomorrow thank you for the advice.
Old May 3, 2013 | 11:30 PM
Boodrow379's Avatar
Boodrow379
I don't think its the fuel pump.. I took the line off the carb and had someone hold it and cranked the motor and it put out gas, maybe its not putting out enough. It is from orilley's. I'll check tomorrow for gas in the oil thank you for the reply
Old May 5, 2013 | 12:18 AM
orich's Avatar
orich
I'd say better do a compression test. Maybe burn out exh. seats a common problem ..
orich
78 Ford F150 460
1978 - 1996 Big Bronco
20
Dec 15, 2016 07:02 PM
shiftonthefly1
Aug 9, 2010 11:11 PM
ghunt
General Automotive Discussion
Nov 18, 2007 12:42 AM
bamfers
Jun 2, 2006 07:07 AM
Shane269
Jul 3, 2005 05:36 PM
