Am I Missing a bracket?
Old Apr 28, 2013 | 11:21 PM
GamerGirlAlice's Avatar
GamerGirlAlice
this may seam like a weird question but not sure if im missing a bracket for my ashtray in my 71 f250. the tray is intact but falls out of dash if u bounce enough the in dash structure is there too. but i think im missing some sort of slider bracket that fits between inner structure and tray. reason i think that is because there is groves in the tray that don't match up to inner dash tack. thinking im missing a middle piece that uses ball bearings to guide the ash tray. id take a picture to show but i don't have the truck right now, it is in the shop having trans rebuilt. it has been over a month since it went in shop. wish i was still able to do repairs my self but this was over my head anyways. im trying to figure out how to fix the ashtray if i can. payday is coming up on 3rd so maybe i can afford to buy from a club member if they have one.
Thanks in Advance, GamerGirlAlice
Old Apr 28, 2013 | 11:36 PM
Gembone's Avatar
Gembone
Maybe this image will help you point out what you are looking for.
Old Apr 28, 2013 | 11:48 PM
GamerGirlAlice
the one on the ight looks like mine the gruves in the tray have nothing n them on mine
Old Apr 29, 2013 | 12:08 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1968/72 ashtray rides on (4) 354872-S ball bearings, (2 per side) which "go away" causing tray to flop around within receptacle. 1967's use a different ashtray, no ball bearings.
354872-S =
NOS PARTS LTD in Waxahachie TX has 4 = 972-937-2201.
ENGLAND FORD in Hinton OK has 5 = 405-542-3242.
DON SANDERSON FORD in Glendale AZ has 71 = 623-842-8643.
GREEN SALES CO. in Cincinnati OH has 456 = 800-543-4959.
Old Apr 29, 2013 | 12:31 AM
GamerGirlAlice
354872-S =
so how would i find the parts to stop it from falling out of tack?
Edit i see the phone numbers now must mised them before posting
Old Apr 29, 2013 | 12:33 AM
Gembone's Avatar
Gembone
I believe he is saying that by putting new bearings in it will fix your issue
Old Apr 29, 2013 | 12:37 AM
GamerGirlAlice
ill have to see how much the nos parts are and try to order 4 on payday
NumberDummy
Look at the parts catalog pic. Ashtray assy (04810) includes tray & receptacle, door and **** sold by themselves.
What are you missing? Probably the ball bearings, 536 of the little charmers listed in post 4.
Old Apr 29, 2013 | 12:49 AM
GamerGirlAlice
by the look opf it im missing the berings and a floating bracket that keeps holds bearings in. it floats between the dash bult in and the acual tray
Edit: looks like i need to get part #04810 (tray & receptacle) to fix the problem
Old Apr 29, 2013 | 09:00 AM
MIKES 68 F100's Avatar
MIKES 68 F100
my truck was missing one bearing too , i just found am ashtray at the local u pick part i got real lucky ash tray was correct color . check ebay i see them on there too .
Old Apr 29, 2013 | 12:56 PM
NumberDummy
Originally Posted by GamerGirlAlice
by the look opf it im missing the bearings and a floating bracket that keeps holds bearings in. it floats between the dash bult in and the acual tray
Edit: looks like i need to get basic part number 04810 (tray & receptacle) to fix the problem
Basic part numbers shown in illustrations. The text section is required to get the complete part number.
D1TZ-1004810-A (replaced C8TZ-8104810-A) .. Ashtray Assy-includes bearings / Obsolete / 1968/72 F100/750.
WESLEY OBSOLETE PARTS in Liberty KY has 1 = 606-7878-5293.
GREEN SALES CO. in Cincinnati OH has 2 = 800-543-4959.
C8TZ-8104810-A =
FREESE MOTORS in Monticello IA has 3 = 319-465-3541.
WESLEY has 4.
GREEN SALES has 14.
Old Apr 29, 2013 | 11:02 PM
70-360fe's Avatar
70-360fe
My 70 f-100 looks like the one on the right. It has a clip that goes on the bottom of the piece with the slots in it. Goes underneath that piece and up the sides them holds 2 steel ***** on each side so the ash tray can move. Look at the junkyard just make sure the holes on clip are not wore out. Mine were that's why I had to replace the clip.
If yours has the clip the holes are most like wore out and the steel ***** have fallen out.
Old Apr 29, 2013 | 11:40 PM
GamerGirlAlice
mine dosent have the entire clip and salvage yards here don't even keep things 10 years old sadly. i put a ad in th wtb section but no replays yet.
Old Apr 30, 2013 | 05:24 AM
70-360fe's Avatar
70-360fe
Maybe someone on the board has a donor truck with an extra one. I could check next time I go to junk yard but been working a lot and it might be a while before I get there.
Old Apr 30, 2013 | 09:54 AM
JEFFFAFA's Avatar
JEFFFAFA
Gamer. I may have one out of my 1971 F100 parts truck. I can check when I get home from work. Will let you know. Jeff
