Engine running WIDE OPEN
Old Apr 28, 2013 | 08:13 PM
Tommky's Avatar
Tommky
I need help please. I have a 1986 F-150 302 with EFI. Cleaned throttle body which was gunked up very bad. Very few items to remove to disconnect body to clean it so very little was done. Excited about running it after cleaning to see if runs any better. To my amazement, engine revs wide open with RPM needle pegging out. Have to turn ignition off immediately as fear of blowing it.
Unhooked battery for 30+ minutes hoping it was some kind of memory setting. No change. Also unplugged Air Bypass valve, no change. Butterflies seem to move easily with no binding. What in the world could I have done that would cause engine to rev to max? Please share ideas if you have any.
Thanks
Old Apr 28, 2013 | 08:35 PM
lmd91343's Avatar
lmd91343
Have you checked for an air leak?
The amount of fuel sent to the engine is not directly regulated by the blade in the TB. Any air leak will increase the engine speed. Also check the top to bottom intake manifold gasket. There are many threads about that check here.
I believe that the computer has a rev limit. I am not sure about your truck's year.
Old Apr 28, 2013 | 08:37 PM
White 97 xlt's Avatar
White 97 xlt
X 2 on a (large) vacuum leak...
Old Apr 28, 2013 | 08:46 PM
ctubutis's Avatar
ctubutis
If it were merely a large air leak (vacuum leak) I would expect the engine to die as it's gonna be too lean of a mixture.
However, lots of air combined with lots of gasoline = full-throttle operation.
Old Apr 28, 2013 | 09:30 PM
Tommky's Avatar
Tommky
After cleaning the TB we replaced the gasket and was very careful to install it and tighten back down. Would a air leak around the gasket cause this kind of reaction? We didn't remove any vacuum hoses and don't see anything that is not connected as expected. Thanks for your thoughts.
Old Apr 28, 2013 | 09:58 PM
kermmydog's Avatar
kermmydog
Did you mess with the throttle position sensor? Did you plug it in?
Craig
Old Apr 28, 2013 | 10:06 PM
Tommky's Avatar
Tommky
Craig
We did not unplug it during the cleaning. I have plugged and unplugged since the problem (revving wide open) began thinking that it might be the culprit. My understanding of this sensor is this just sends position info to other processes and does not control the actual engine rpm. Would u agree?
Old Apr 28, 2013 | 10:26 PM
jroehl's Avatar
jroehl
As more air gets into the engine via an air leak, the O2 sensors detect the exhaust starting to lean out and the computer directs the fuel injectors to shoot more fuel in, resulting in the revving engine--the computer just thinks that you've put the accelerator down (it's really an "air" pedal, not a "gas" pedal!). The only thing I'm not sure about is how much the computer considers the input of the TPS in all this. My experience with a bad TPS was that the engine ran and revved fine in park, but the shift points were royally screwed up when I was rolling.
Jason
Old Apr 28, 2013 | 10:46 PM
Tommky's Avatar
Tommky
Jason
The problem is eerie in that the engine revs up to wide open instantly. There is no delay. As soon as the starter disengages the engine is pushing the rpm hand to the max. I'm afraid to test it after making a change for fear of damaging the engine. Your description of history with the TPS seems plausible to me.
If just an air leak would cause this I would think that others would have experienced this and reported similar experience. I may have to replace the TPS and/or Air Bypass Valve to rule them out.
Old Apr 28, 2013 | 11:51 PM
ford2go's Avatar
ford2go
I would suspect an electrical issue -- possibly with the throttle position sensor -- it 's telling the computer how much throttle is applied -- how fast you WANT to go.
Easy enpugh to ohm out the tps --but you may want to try to check the harness as well. If some of the cleaner got in the connector it could have caused a partial short.
One other possibility is the cruise control -- assuming you have one.
Not sure if there is a rev limiter in that year. I was driving an 80's era Ford once and just for giggles, I slipped the tranny into neutral while I had the cruise on. Engine started to wind out and I quickly killed the cruise .
Good Luck,
hj
Old Apr 29, 2013 | 12:08 AM
lmd91343's Avatar
lmd91343
Is the TB blade stuck open?
Jason is right on with his explanation.
Good luck!
Old Apr 29, 2013 | 12:11 AM
Tommky's Avatar
Tommky
Definitely not. They are about 90% closed prior to starting and they both can move normally. No hangs in linkage.
Old Apr 29, 2013 | 07:13 AM
rla2005's Avatar
rla2005
Disconnect the IAC, Idle Air Control valve. This will take the computer control out of the equation. If the idle RPM is still high/maxed out you have an unmetered air (vacuum leak) problem. Did you remove and clean the IAC while you were cleaning the throttle body?
For reference: Fuel Injection Technical Library » Idle Air Bypass (IAB)
Old Apr 29, 2013 | 07:37 PM
Tommky's Avatar
Tommky
Problem solved
Thanks
Thanks to everyone for your helpful comments. The problem was due to the butterfly plates not being reinstalled properly. They would rotate but only so far. They could not fully close and that was the main problem in causing it to rev wide open. Several of you made comments that were very close and it just took another close look to figure it out.
My son has been driving the truck and he is the real enthusiast, just not having the knowledge and experience to take on cleaning the gunk out of the throttle body. After the project "blew up" I had to try and learn how it worked. We had a nice discussion on lessons learned.
Thanks again.
Old Apr 29, 2013 | 07:42 PM
dixie460's Avatar
dixie460
Glad y'all got it fixed.
