99 powerstroke"fuel in oil and smoking"
Old 05-07-2013, 02:10 PM
1chumley1's Avatar
1chumley1
1chumley1 is offline
I dont no i dont have a good sniffer.Idk on the oil change.
Old 05-07-2013, 02:16 PM
1chumley1's Avatar
1chumley1
and i just changed the oil ran it twice for maybe 15min ea.time. the dip stick read almost full now its a little over full.
Old 05-07-2013, 02:27 PM
cjgray1974's Avatar
cjgray1974
cjgray1974 is offline
Like a quarter inch on the dipstick? Might want to do a compression check. I know with semi's, dumping a lot of fuel into the oil could mean bad rings and the fuel is getting past the piston rings, but usually have a loss of power and poor performance. Sorry to worry you. Hope it's something simple.
Old 05-08-2013, 09:56 AM
Christof13T's Avatar
Christof13T
Christof13T is offline
Again...
I have a premonition...
Old 06-10-2013, 10:59 PM
1chumley1's Avatar
1chumley1
ok i started to tear it down to do a compression test,i noticed the nine pin plug was burned up in two spots, three glow plugs were had to get out it was like there was a lot of carbon build up holding them in.
Old 06-11-2013, 06:01 AM
Tugly's Avatar
Tugly
Tugly is offline
Autolites?
Old 06-11-2013, 10:02 AM
Christof13T
Did you complete the compression test?
If yes, what were the numbers?
Burnt pins and bad icp can and usually do cause rough running and smokey conditions...
Keeping fingers crossed for you man and hoping for good compression.
Old 06-13-2013, 10:46 PM
1chumley1's Avatar
1chumley1
I must be doing something wrong. there is fuel popping out of the other GP holes
Old 06-14-2013, 04:43 PM
1chumley1's Avatar
1chumley1
ok i started the compression test and i have fuel shooting out my last glow plug hole on the driver side.
Old 06-14-2013, 04:57 PM
Christof13T
That shouldnt happen unless you also pulled the injectors...
The injectors need to be in their holes and torqued down for compression test...
Otherwise... if you just mean quick puffs of fuely mist... thats normal. They should puff a couple of times then run clean... make sure injectors are unplugged... best way is the valve cover harness connector... or the big 42 pin connector.
Old 06-14-2013, 06:51 PM
1chumley1's Avatar
1chumley1
i just tried to do a test on the GP hole that the fuel is coming out of and went to release the pressure and fuel leaked out the release button.
Old 06-14-2013, 07:13 PM
Christof13T
Are your injectors uplugged?
  #28
Old 06-14-2013, 08:12 PM
Bonanza35's Avatar
Bonanza35
Bonanza35 is offline
Unplug the 42 pin connector like said above. That should keep the injectors from pumping fuel.
  #29
Old 06-14-2013, 08:17 PM
1chumley1's Avatar
1chumley1
the injectors are unpluged and the 42 pin is also unpluged
  #30
Old 06-14-2013, 08:21 PM
Christof13T
You need to figure out if its fuel or coolant.
If its fuel... i think you got bad problems...
If its coolant... maybe just a cup
Quick Reply: 99 powerstroke"fuel in oil and smoking"
