Radius Arm Questions
The original nut, washer, bushing, and second bushing came out nice. Pretty sure the 'last' washer that is up against the nub of the radiius arm also comes off? I tapped it with a small hammer and it easily came off. Was it supposed to be built into the radius arm? I say that because after I tapped it off, the ridge that it sits on, part of it (maybe 1/4 of the ridge diameter) rusted/chipped off and that washer no longer fits perfect/even against the stop.
I noticed there was lots of rust on the radius arm, under where the bracket and bushings had been. Is this normal? Should I try to take a wire brush and clean it up best I can?
Lastly, a parts store last year had sold me Moog part K8295 for the bushing kit, but this just doesn't look to be the right part. Should I have looked instead for K8146? or K80004?
Sorry for the long post.
Mine actually snapped. Took me a while to find a good set to replace them. I've also thought about seeing if a machine shop could replace the rod/bolt portion on my original set, just to have spares.
