I just purchased everything needed for a ARP head stud install in hopes of lowering cost at the shop here in Anchorage. Saved $1k compaired to their pricing. Now he will won't touch it. The only other shop will do it though for $4600 using my parts minus warrenty. So what I need is some no BS on how bad is it for a guy to do this, that has good mechanical skills and a shop to work in, The auto skills center on base. As of now my truck has everything done to it Delete/Coolant Filter/FICM/Blue Spring/Updated Oil Cooler/ICP everything was completed by me. Thanks
just theo other day I saw 1600.00 charged to owner for maybe 4 phone calls and a 16K check that rode for maybe 30 days MAX before the contractor got reembursed
That is a little steep for labour, and this is coming from a dealer tech. Even at the dealer I'm at, at $114 per hour labour you'd be looking at about $3000 to $3500 for this job, in CANADIAN dollars too.
Don't do the studs yet unless absolutely necessary. Hang on to them until you can get to a different city/Canada/or the lower 48 and have them done then. Take your time, shop around.
My Freind , Construction of this motor is great , this will help, LOOK in the CHAPTERS for your Area,Ask your mediator. P.m ( privet messege) Theres good Info here to read in Tech folders. M- Chan would be ur Guy for that area.
Bud if you did EGR Deleates and Oil Coolers you CAN DO THIS
Look how much more you can do or save with $$4600.00
Theres HUGE AMOUNTS of info here and the folks are great and can get you threw any Snag
