Emissions not ready?
Old Apr 26, 2013 | 07:11 PM
king-david's Avatar
king-david
So I took my truck to get inspected/emissions done... And the emissions not ready message came back. What in the.... He said maybe put 100 miles or so on it from when I replaced the battery. Is that the answer? I've never seen such a thing.
Old Apr 26, 2013 | 08:17 PM
ExxWhy's Avatar
ExxWhy
Sounds about right. The computer typically needs a few cycles to check everything after it's reset. Disconnecting the battery does reset it.
Old Apr 26, 2013 | 08:57 PM
MURDOMINO's Avatar
MURDOMINO
yes.
the PCM runs different tests to ensure each system is operating within its specified range. Within the last six years California has now required that no more than two monitors be allowed to be in the "not ready" status. Each monitor requires its own unique drive cycle in order to qualify it as ready. Fords generally arent very difficult and you should be able to get them done within 100 miles. i could explain a drive cycle, but they are crazy detailed, I.E. from a stop accelerate to 20, decel without using the braked to 10mph's within two seconds, accelerate again back to sixty... things of that nature.
Old Apr 26, 2013 | 09:00 PM
king-david's Avatar
king-david
Well, I guess I'm going to have to drive un-inspected for 100 miles haha
Old Apr 26, 2013 | 11:49 PM
az_r2d1's Avatar
az_r2d1
I have a similair thing, except it NEVER goes to ready. It's the evap test. No light or codes set.. I've driven hundreds of miles... still not ready on the evap test.
If you use the torque app on android you can see which test is not ready.
Old Apr 26, 2013 | 11:52 PM
Apocalypse's Avatar
Apocalypse
Also you can burn CA. to the ground, those emission test are POINTLESS!!!
Old Apr 26, 2013 | 11:54 PM
king-david's Avatar
king-david
So you just aren't getting emmisions done?
Old Apr 26, 2013 | 11:55 PM
az_r2d1's Avatar
az_r2d1
Amen.
Another way for big government to put their hands in our wallets.
Old Apr 27, 2013 | 03:13 AM
dirtydeeds's Avatar
dirtydeeds
in CA you're allowed to have one monitor that hasn't run and it'll still pass. That 1 monitor is usually EVAP since it takes the longest to run.
If you're in a hurry, just get a buddy who is a mechanic and use his code scanner. There are ones that can 'force' a monitor to run.
Old Apr 27, 2013 | 08:22 AM
tdappleman's Avatar
tdappleman
You can run through the OBD2 drive cycle which causes the major monitors to run. You can test individual parts using most scanners (not code readers). Those tests do not cause the readiness of that specific component to go to 'ready'. The Ex should be tested as a medium duty truck which means it shouldn't need to be ready as it most of the time will never be ready. Mine has never gone to ready in 4 years - even after doing the drive cycle multiple times.
Ford Motor Company Driving Cycle
Old Apr 27, 2013 | 09:33 AM
Bigpipes 35's Avatar
Bigpipes 35
That is correct , the testing station needs to know that it is a vehicle with a GVW over 8500 pounds. Because of this our system will always say not ready and if the tester has any idea what he is doing he will know this.
Old Apr 27, 2013 | 11:04 AM
king-david's Avatar
king-david
You mean the fine gentleman at NTB are not capable inspectors?
Old Apr 27, 2013 | 03:06 PM
az_r2d1's Avatar
az_r2d1
CA models are obd2 compliant, and will go to ready status.
Why else implement it....
Old Apr 27, 2013 | 04:22 PM
Bigpipes 35
Where in his post do you get that it is california emission equiped
Old Apr 27, 2013 | 04:47 PM
RACERX7775's Avatar
RACERX7775
Since when did any X have California emissions. It's amazing that there are 10's of 1000's of inspection stations and tons more inspectors that don't know the laws. And worse than that, we, as owners have to keep investigating on our own to figure out problems. They should know that the V10 X has a GVW higher than 8500 lbs., and therefor requires a 2 speed idle test and will NEVER show that all the perameters will NEVER be ready. The weird thing is, an X with the 5.4 V8 will show ready and will get the standard emissions test.
