460 water pump
Old Apr 24, 2013 | 11:41 AM
jswisc's Avatar
jswisc
460 water pump
I replaced the pump on a 93' 460. The old pump had a plate on the back, the new one didn't. It also came with one gasket. I obtained another gasket and installed the new pump w/ the plate from the original. Probably a mistake as my crank pulley is now slightly offset from the pump pulley, say the width of the plate. I guess the plate is a spacer and not needed?
Old Apr 24, 2013 | 01:59 PM
jswisc's Avatar
jswisc
After searching for the water pump plate most are saying the plate is necessary, but not all. I will try to shim the crank pulley. Any issues there?
Old Apr 24, 2013 | 03:31 PM
monsterbaby's Avatar
monsterbaby
IIRC some pumps were intended to be ran with, some where intended to be ran without.
so when you put the plate on a pump that didn't have one, the pulleys won't align.
Jpegg01
Jul 21, 2018 01:09 PM
DieselCamper
20
Nov 1, 2016 01:38 PM
roughcreekgang
Aug 2, 2007 09:27 PM
William
Sep 27, 2005 06:41 AM
