Hi,
a) Can anyone explain the EPC solenoid sequence of operation. For example;
Minimum PCM pin 38 voltage, maximum EPC current, solenoid on, valve open/closed?, control fluid pressure min/max?, line pressure min/max?
b) How to increase shift firmness by changing input(s) to the PCM for the shift time only?
Any thoughts appreciated
'94 F-150 4.9L
cheers, dave
