Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
advice on impact wrenches?
Old Dec 14, 2013 | 03:09 PM
iggybob44's Avatar
iggybob44
I just bought a Milwaukie 18V one, its spec'd at 450 lbs of torque, its listed as the High Torque model.....i will try it out when its not so cold, because id like something i could toss in one of the trucks in case i need to change a tire while on the road.
Old Dec 25, 2013 | 08:35 PM
joey2fords's Avatar
joey2fords
as a strictly backyard guy, i absolutely LOVE my 120v gun from canadian tire, bought on sale for about $120.00, if i remember correctly.
there is no adjustment on it, but it works wonderfully for wheel lug nuts ... no more wheeling the little compressor out of the shed, unravelling the air hose, unwinding the electric cord, oiling the tool, waiting for the compressor to fill up (several times, for 4 wheels).
as we know, tire shops are famous for overtightening lug nuts, and my amateur air set-up often wasn't up to the task. this electric gun hasn't failed yet (but i have only owned it 6 months).
Old Dec 25, 2013 | 10:56 PM
BigBlockF350's Avatar
BigBlockF350
I'm looking into buying a cordless 3/8" or 1/4" small impact/driver in the next few weeks for general shop use. Any recommendations? I've looked at what Matco has to offer, but still not completely sure what I'll get.
Old Dec 26, 2013 | 07:11 AM
JWA's Avatar
JWA
Matco and Snap On both offer pretty awesome sounding cordless impacts--at least on paper AND before the price is considered. From what I see at shops I visit for work most last a good long while---and they're not babied at all.
Personally I'd look to Milwaukee in the M18 range---in fact depending on what you'll be using it for the M12 Fuel stuff is pretty amazing. I'm using the "older" M12 and its unbelievably great for its purpose. Battery life is just not to be believed.
As much as I detest DeWalt in general they have a few great designs, their XRP batteries also of very long life between charges---a good choice if the budget is a prime factor.
Purchasing either brand is probably most affordable through eBay or Amazon---just make sure whoever's selling them is authorized by Milwaukee/Dewalt otherwise you're SOL on warranty coverage.
HTH
Old Dec 26, 2013 | 09:52 AM
Skip1970's Avatar
Skip1970
makita makes the only cordless tools that last and have a nice 1/4 driver impact
dewalt has went so down hill since they started making them in china now they are pure garbage.
Old Dec 26, 2013 | 01:16 PM
iggybob44's Avatar
iggybob44
HTH
I have a TON of Milwaukie M12 tools, everything from the Hackzall, 3/8" ratchet, drills, impact drivers, and so on.......Ive probably got a dozen M12 batteries, both the compact and High Caps, still havent had one die........I just bought an M18 1/2" drill with compact battery, and two high capacity battery/charger combos, and i tried out the M18 High Torque 1/2" impact wrench i bought recently........VERY IMPRESSED with it, it takes the lug nuts off my two Highboys effortlessly......
Old Dec 26, 2013 | 04:00 PM
BigBlockF350
I get 50%+ off with Matco right now as a student Similar with Snap-On. I will look hard at what both offer.
Budget is not a huge factor. If it'll work well and last, I don't mind paying for it.
I'll check them out. Thanks!
Old Dec 26, 2013 | 05:38 PM
JWC 3's Avatar
JWC 3
My old Snap On 3'8 cordless recently died . I am going with Dewalt for a replacement . I did a bit of research before deciding .I love my Snap on , But...
Old Dec 26, 2013 | 06:50 PM
BigBlockF350
Thanks for the input. I'll have to look at all of my options. Report back with what you buy!
Old Mar 2, 2014 | 10:07 PM
NORTHERNF250's Avatar
NORTHERNF250
I have both the DeWalt and Snap-On 3/8 and 1/4 inch cordless impacts I use them equally but when you need power go with the Snap-On . I also have the half inch snap on and it easily is becoming my most used tool.
Old Mar 3, 2014 | 06:24 AM
BigBlockF350
I got a 19.2v craftsman 1/2" impact almost 2 months ago. I think it was about $200. I've been happy with it so far. It's got plenty of power, and also works well with a 3/8" adapter for smaller applications. Oh, and it came with 2 batteries which is a big plus.
Old Mar 4, 2014 | 08:49 PM
NORTHERNF250
Two batteries is a big plus for sure,and for $200 you can't go wrong hope it works good for you for a long time
Old Mar 5, 2014 | 01:17 PM
  #28
BigBlockF350
Yeah, hope it'll last. Seems pretty good so far. No issue breaking truck lugs loose and stuff, but definitely not as strong as an air gun.
Old Apr 21, 2014 | 12:09 PM
  #29
Island'r's Avatar
Island'r
Well, I went to do some work on the truck yesterday... I recently installed an Ingersoll Rand 60 Gallon compressor in my shop, so it was time to put it to work. I have a cheap set of air tools that have been in my box for years in the hopes I would one day have a compressor capable of powering them.
They're a CH Standard duty. Figured they'd do the job till I could afford something better. When I worked at Ford the guys starting out were running Chicago Pneumatics and the bulk of the seasoned guys were using snap-on. I had hoped to get something along those lines ONE DAY.
Well my piece of crap CH wouldn't even take the lugnuts off, even at the highest setting with the psi cranked over the "recommended" setting. I broke them loose with a breaker bar, and they were right around the 100ft/lb mark...
It will make a good hammer but that's about it... I don't usually cheap out on tools, and this proves YET AGAIN why....
Old Apr 24, 2014 | 02:24 PM
  #30
lariat97's Avatar
lariat97
You can't beat a Ingersoll Rand impact wrench for air tools.I have one that's 20 years old & still works good. I use Milwaukee m12 for my cordless tools great power & battery life. I want a 12 inch m18 impact next
KC8QVO
Garage & Workshop
Aug 16, 2018 08:55 AM
Beechkid
Garage & Workshop
Apr 7, 2010 06:26 PM
DSMMH
Mar 25, 2009 09:39 AM
SwOkcOffRoader
Garage & Workshop
30
Oct 11, 2007 06:54 AM
grease monkey
Garage & Workshop
40
Dec 18, 2004 08:36 AM
