Sponsored by: Auxito
4 Wheel Drive not engaging
Old Apr 22, 2013 | 05:11 PM
Davwilson's Avatar
Davwilson
Question 4 Wheel Drive not engaging
Say anybody have any ideas why my 4 wheel drive is not engaging on a 2001 F150. The indicator lites on the dash illuminate to suggest that the truck is in 4 wheel drive but sigh...it stays in 2 wheel drive. No gross sounds and the idicator lites are not flashing. Could this be a fuse or a relay issue of some sort. Any ideas or what else should I try? Thanks!
Old Apr 22, 2013 | 08:14 PM
Bluegrass 7's Avatar
Bluegrass 7
Check the actuator on the front axle for moving the locking collar.
The system can't tell if the actuator has done it's job.
The dash light is operated from the firewall solenoid, and assumes the actuator will complete the lockup of the front axle.
Good luck.
Old Apr 22, 2013 | 08:45 PM
mechanic58's Avatar
mechanic58
Need to check all the vacuum lines associated with this system. I'm betting you have a broken one somewhere under the hood in the vicinity of the battery. There is a vacuum reservoir behind the battery. If any of the lines leading to it are broken, it won't engage the 4wd. Chances are you dashboard isn't working properly either.
Old Apr 22, 2013 | 09:15 PM
Davwilson's Avatar
Davwilson
Thanks..I'll give that a shot. Appreciate the advice!
cullscott
1997 - 2003 F150
Oct 6, 2012 10:42 PM
ChickenChaps
1983 - 2012 Ranger & B-Series
May 22, 2008 05:20 AM
crashtester
Feb 3, 2007 09:04 AM
shoeman502
1997 - 2003 F150
Nov 25, 2006 09:49 PM
pucktastic
1997 - 2003 F150
Jan 9, 2006 09:06 PM
