Good Morning guys!
What exactly does a chip to to give me 100 more hp? Is it a combination of changing the shift points and raising the boost in the turbo?
For someone wanting a little more power this seems to me to be the first and easiest choice.
If I where to add a chip which would you guys recommend? Would 100 hp stretch my head bolts?
I just was curious what other have experienced.
Good Morning guys!
Thank you
Todd
I can't comment on exactly what parameters a chip changes to the PCM, but it's a great way to wake up an old truck. You aren't going to see 100hp increase with stock injectors. The most you'll see is about 55-65. Before a chip, intake, exhaust, and gauges (pyro, boost, trans) are a must.
With stock injeftors you won't get a 100hp
You'll get around 65hp even in the 100hp
Tuners play with timing, HPO , injector PW
Thanks travis and fordpride. So where can I find info on hat matches? For example: stage one injectors. Better intake, nice exhaust and chip. That's good for 100 hp?
Right here on FTE! You're smack dab in the middle of the best place there is to get info on everything for your truck. LOL!
In this order
Make sure the truck is in perfect running condition
6637 intake
3" down pipe 4"exhaust
Gauges boost, EGT, trans temp if auto
Chip with custom tunes
Injectors
That should keep you busy for a while
In this order
6637 intake
Injectors
Fordpride,
I just red the technician turbo service guide.............................SWEET!!!!! Thank you for posting that link again. I downloaded all the guides that pertain to my motor.
Alive and kicking my friend! Sorry I aint been around much lately, I try to keep up with whats new here haha. Working full time now and going to school is keeping me busy. And trying to finish my interior overhaul on the side. Ill post pics of that when its finally done! Just need to find some Lariat SD seats....
