Big Block 460 Emissions Removal
So here we go..........
I decided to start with this canister.
It's mounted to the passenger side fender well with Three studs running through to the underside of the well.
I used a 7/16 socket to remove these bolts. In the pick I left the nuts loose on the studs so you can see which ones they are.
For those of you that are trying to sacrifice these parts like I am, be carefull to not snap these studs as time has taken a toll on the hardware. You can see I snapped one. Guess I should have worked the nut back and forth a little more.
Anyway........ Moving on........
The air pumps were next.
After taking the belt off by removing the 9/16 adjustment bolt on the left lower side of the left air pump, there is one more longer 9/16 bolt in the rear of the same pump to remove. I then removed the hose that runs between this pump and the canister that I unbolted from the passenger inner fender well. To loosen the hose clamps, I used a 5/16 socket.
I could now remove the pump completely.
For the removal of the right side pump, you have to remove the pulley by removing the Three 10mm bolts. Then it's straight forward just like the last one.
I chose to leave this assemble mounted to the pump during removal. I traced the hoses back to what they were connected to, loosened the hose clamps, and disconnected the hoses there. This pump was now ready to be completely removed from the truck.
This is what's left after the pumps are removed. That's one heck of a bracket!
This mount also serves as an Alternator mount. I'm going to remove this mount and take the plasma to it cutting most of the material off except for what's going to serve as spacers for the alt just so I know that it will align perfectly with the other pullies. Here it is removed.....
Ones again I left the mounting bolts in so we can see the location.
You can see with the Two bolts in the top ears of the mounting bracket that the top right threads into the top of the water pump on the opposite side of the crossover hose.
The left one threads directly into the passenger side head in the top left corner of my pic.
And the long bolt in the middle threads through the Alt, and through the water pump into the block to hold it in place on the block. I used a 9/16 socket to remove the bracket hardware and 11mm to remove the electrical from the back of the Alt.
The next thing I did was move onto the plumbing that transports the air into the exhaust manifolds. Keep in mind, knowing that I was going to be doing this job, a couple weeks ago, literally every day, driving it or not, I'd spray the bolts down with PB Blaster. EVERY DAY! As much as I wanted to salvage these I was unable to do so. It was impossible to get a good enough grip on these with the open end of a wrench without rounding them. So I cut right above the nut, bent the tube above my cut out of the way enough to get the box end on them. Surprisingly I got no hard time out of these. They broke free fairly easily. After that, I removed the rubber air hose from what looks like an equalizer, or collector and removed them completely from the vehicle. I used the same process on both sides of the engine.
It looks like we're dealing with 5/8 inverted flares here. I'll find out the thread pitch and get some plugs ordered up. I know I won't be able to find these in the local parts store. I'll check tomorrow on the plugs and hopefully get my Alt bracket cut.
This is all I got done for the day. Weather prohibiting ill be back at it tomorrow.
I'll probably have some questions for you guys being that I've never done this before. There is a lot of crap under there!!!
Comments are welcome, and I'd love to hear suggestions.
Until tomorrow then.
Unlikely you'd have that happen, but it would be nice to make sure it doesn't.
EGR, mine had a BB installed in the vacuum line from shortly after I bought it. Leave the thermal valve in the spark advance though.
Ford had a few cars blow up when evaps first were intro'd. A few people fueled up in a cold weather area and drove south, into a hot day. More fumes and liquid than the system could handle. Poof! Like I said, probably won't happen, but have you ever been involved in a gasoline fire?
