Sponsored by: Real Truck
Leveling kit questions
Old Apr 21, 2013 | 01:05 PM
bulldog80's Avatar
bulldog80
I just bought a 2005 F350 4x4 and am new to the Ford truck world. I want to put on a 2" front leveling kit and am leaning toward a bottom mount spacer kit. Do any of you have a preference to any certain brand? Also, are any other type of brackets necessary to maintain the front end geometry or can I get away with just the 2" pucks? I don't do any serious off roading just don't like the nose down look. Thanks in advance guys
Old Apr 21, 2013 | 11:15 PM
jswartz84's Avatar
jswartz84
I used Ready Lift. It has the spacers in the bottom and some shock relocation mounts along with the track bar mounts. I have had it on for 5 years with no problems. My tires rub with my stock wheels at full lock, but do not rub at all with my aftermarket wheels.
Old Apr 22, 2013 | 10:27 AM
bulldog80's Avatar
bulldog80
Thanks guys. If I stay at 2" or less do I need to get one of the kits with the shock and track bar brackets?
Old Apr 22, 2013 | 11:53 AM
PSDlongbox's Avatar
PSDlongbox
I did the ready lift billet spacers with 4 inch rear blocks and I love it. Still a slight rake, but looks good and don't require extensions brackets etc.
Old Apr 22, 2013 | 01:37 PM
bulldog80's Avatar
bulldog80
PSD, Did you just go 1.5" in front then?
Old Apr 22, 2013 | 01:42 PM
PSDlongbox's Avatar
PSDlongbox
Yes. I can get some pics/measurements if you like. Also what springs do you have in the front? C codes with the 2.5 kit actually make it a bit nose high from buddies trucks, but results may vary.
Old Apr 22, 2013 | 02:07 PM
bulldog80's Avatar
bulldog80
Yes I have the C codes and didn't want to end up nose high, thats why I was thinking 2" at the most. Don't mind it a little nose down just wanted it closer than it is right now.
Old Apr 22, 2013 | 02:09 PM
PSDlongbox's Avatar
PSDlongbox
That is why I went with the 1.5 vs 2.5.
Old Apr 22, 2013 | 02:31 PM
bulldog80's Avatar
bulldog80
Are you running Rancho 5000's or 9000's? My factory shocks are shot too.
Old Apr 22, 2013 | 02:41 PM
jswartz84's Avatar
jswartz84
If you stay with a 1.5" you shouldn't need the shock brackets but if you are replacing them anyway just buy them a little longer. Not positive on the track bar mounts, but I think if you lift it at all you will need them. I didn't notice any difference with my factory wheels but with my offset on my aftermarket wheels it was obvious. As far as shocks are concerned, I believe 5000 are more suitable for 1/2 ton trucks and 9000 are more suitable for 3/4 and 1 tons.
Old Apr 22, 2013 | 04:58 PM
Rancho Suspension's Avatar
Rancho Suspension
Former Vendor
I tend to agree with this on a personal level. The 5000's are a great shock for a 3/4 or 1 ton, but the adjustablity of the 9's are REALLY nice if you are towing often.
Old Apr 22, 2013 | 05:07 PM
bulldog80's Avatar
bulldog80
Thanks for the input. I think I'll go with the 9000's too. I'm assuming that I'd want the RS999043 on the front with the 2" levelers?
Old Apr 22, 2013 | 05:18 PM
Rancho Suspension
Former Vendor
Yes sir!
Old Apr 26, 2013 | 12:02 PM
bulldog80's Avatar
bulldog80
Rancho if I go with only 1.5" spacers do i go stock length shocks or the 2.5" longer ones? Don't want to top or bottem em out
Old Apr 26, 2013 | 12:06 PM
2006lariat's Avatar
2006lariat
Check out the 7000mt too! They ride good, and control the Super Duty pretty well. I will know more about how they handle towing, more this weekend, but I don't forsee any problem's.
