Rear Spring Conversion
Old Apr 21, 2013 | 11:20 AM
rhtrigger's Avatar
rhtrigger
Has anyone converted their '99 to '07 truck to the longer '08 rear leaf springs?
Old Apr 21, 2013 | 03:22 PM
cheezit's Avatar
cheezit
why would one want to? i guess if you really wanted to you could move the perches
Old Apr 21, 2013 | 06:46 PM
JD_F250's Avatar
JD_F250
I changed mine out but not for stock ones. I had a company here in WI custom make me some. They make leaf springs for train cars. For $400 plus tax out the door I got a brand new set of springs with bushings. They said they are not quite 1 1/4 ton. I say they are one ton so I dont get the itch to put more weight than I should in the back.
Old Apr 21, 2013 | 07:07 PM
acf6's Avatar
acf6
Originally Posted by cheezit
why would one want to? i huess if you really wanted to you could move the perches
apparently its a pretty popular mod for people with more money than they know what to do with. i guess it rides better?
Old Apr 21, 2013 | 07:29 PM
cheezit's Avatar
cheezit
no iirc there was an issue with towing trailers on the 08 were the back end sagged a little to much. I could be worng on that though.
either way not a hard thing to really do cut rivits off of purches and relocate them to fit the 08 srings.
I will say punding out frame rivits is a pain.
Old Apr 21, 2013 | 07:30 PM
acf6's Avatar
acf6
i know people do the conversion because theyre like 8" longer springs so they ride better
Old Apr 24, 2013 | 07:30 PM
rhtrigger's Avatar
rhtrigger
So the procedure is to relocate all four spring hangers to accomodate the longer springs for a better ride. Is that the correct understanding as for everyone else as well?
Old Apr 24, 2013 | 08:01 PM
cheezit's Avatar
cheezit
relocat as required. set the axel up varifiy correct pinon angle and move the hanger perch as needed would be my method if i were to do it, but ive not tried it before and have done 0 research on the subject
Old Apr 24, 2013 | 09:34 PM
Monster-4's Avatar
Monster-4
Here is write up.
https://www.ford-trucks.com/forums/9...onversion.html
And another to 2011 springs.
https://www.ford-trucks.com/forums/1...my-2005-a.html
Old Apr 24, 2013 | 10:01 PM
RPM371's Avatar
RPM371
Why not just add airbags? That made a huge difference in my '06 and the kit was no drill.
'99F250
Dec 23, 2015 04:00 PM
bluestang65
Oct 14, 2010 01:53 AM
RawPower
Jun 16, 2005 02:58 PM
RickyBR
Sep 6, 2004 09:50 PM
cheappower82
Sep 16, 2003 02:54 PM
