Code meanings
Old Apr 21, 2013 | 08:23 AM
brcwelding's Avatar
brcwelding
Code meanings
I just did a self test on my 88 f250 351w and got some codes that i dont know the meaning of. I got codes 21,24. ECT out of self test range .3-3.7 volts.ACT sensor out of self test range .3-3.7 volts. I dont know what this means and i was wondering if somebody could provide some insight on how to fix this.
Old Apr 21, 2013 | 11:03 AM
88LX5.0H's Avatar
88LX5.0H
You'll get the ECT code if you test when the truck isn't up to operating temperature. If the truck was cold when you ran the codes, don't worry about the ECT one. ACT is Air Charge Temperature, that's the sensor that senses the temperature of the air going into the engine. That one would be caused by a bad ACT sensor or wiring issue.
Erase the codes and then go drive it for about 10-15 minutes and dump the codes again. I doubt you'll get the ECT code, but if you get the ACT code again it's either time to replace the sensor or start checking wiring.
Old Apr 21, 2013 | 05:57 PM
DBGrif91's Avatar
DBGrif91
Agreed. More information here:
Fuel Injection Technical Library
90fordf-250
Jan 2, 2012 10:34 PM
mhamrick56
Feb 22, 2010 12:12 PM
danield
Mar 5, 2008 09:43 PM
shorthair
Oct 22, 2007 10:42 PM
Tim Dawson
Bronco II
Apr 28, 2007 07:57 PM
