Part Interchangeability
Old Apr 20, 2013 | 11:49 PM
jgavac's Avatar
jgavac
I found a good deal on a set of captains chairs and a tailgate from a 86 f250, and I'm wanting to put them on my 87 f250. I'm pretty sure the tailgate swaps, I'm just wondering if the chairs are a direct swap or if I'll need to change out the brackets.
Both trucks are supercabs
Thanks
Jameson
Old Apr 21, 2013 | 12:05 AM
BruteFord's Avatar
BruteFord
Thanks
Jameson
From my understanding "direct swaps" on seats can be tricky. It's not the 86-87 style change that is the issue in this case. It's the cab styles that get ya. Each have a unique floor, a crew is just 2 regular cabs ro reg-crew swap. But you have an extended cab, it's unique is the trick. For a direct bolt in they have to be ex-cab seats.
Old Apr 21, 2013 | 06:58 AM
tjc transport's Avatar
tjc transport
i ain't rite
captains chairs should have 4 bolts per seat mounting with their own slider mechanisms.
if your 87 has captains chairs in it already, they should bolt rite in. if the 87 has a bench seat in it you will have to drill holes and strengthen the floor pan to mount the captains chairs.
. and i doubt the tailgate will work. if i remember correctly, the 86 has the pin through plate style gate latch, the 87 will gave the door bolt style latch
Old Apr 21, 2013 | 10:15 AM
jgavac's Avatar
jgavac
Well i guess it was good that I asked about thr tailgate.. I thought they were the same across the bullnose and bricknose trucks.
Both trucks have the same cab configuration. My truck has existing captains chairs. Does it make a difference that mine is manual and the other is auto?
Old Apr 21, 2013 | 02:56 PM
tjc transport
i ain't rite
nope. if you have captains chairs in you truck now, the others should bolt rite in.
JD86F150
Jan 13, 2017 02:41 PM
MUSKRATT2
Jun 23, 2011 06:45 PM
chad85
15
Jan 3, 2009 07:43 PM
Bigredgashawg
Dec 15, 2003 01:22 PM
jgibbins
Paint & Bodywork
Mar 18, 2003 07:38 PM
