axle seal question
Google Image Result for http://ylobronc.users.superford.org/chassis/innershaft.jpg
This is from a D44 but there are almost the same I believe, you can see the C clip in the blow up
http://i917.photobucket.com/albums/a.../4x402copy.jpg
But would you look at that, learn something new every day.
OP, you're going to have to get into the pumpkin (differential) to remove the c-clips to get that axle out
Deffinately not the best design around. All I wanted to do was change the u joints, ended up with the whole front axle disassembled.
