Sponsored by: Auxito
Heater fan high only
Old Apr 19, 2013 | 04:23 PM
FordLou's Avatar
FordLou
Hey guys,
Did a quick search and couldn't find info if anyone can help. My '99 F150 suddenly lost all interior heater/ac fan control settings except for Hi. Is it the switch or something else in the circuit? Thanks for any info.
Lou
Old Apr 19, 2013 | 06:06 PM
projectSHO89's Avatar
projectSHO89
See HVAC FAQs. Link in signature below.
Old Apr 19, 2013 | 06:48 PM
JWC 3's Avatar
JWC 3
Most probable cause would be the blower motor resistor . See it a lot .
Old Apr 19, 2013 | 07:55 PM
FordLou's Avatar
FordLou
Can you tell me where it's located exactly? That sounds right. Thanks.
Old Apr 19, 2013 | 07:56 PM
LxMan1's Avatar
LxMan1
ductwork near the glovebox
Old Apr 19, 2013 | 11:33 PM
FordLou's Avatar
FordLou
Gotta get behind the glove box in the passenger compartment to reach it, right?
Old Apr 20, 2013 | 06:53 AM
R Pope's Avatar
R Pope
Mine works sometimes, sometimes high only. Poor connection on the switch, I think The temp control quits and starts randomly, too.
Old Apr 24, 2013 | 06:38 PM
FordLou's Avatar
FordLou
Just an FYI update for anyone who may have this issue. The blower motor resistor was the problem. After finding voltage at the incoming wiring to the resistor, what else could it be.
Also, the resistor is not directly behind the glovebox on, at least, the '99 F150. Actually, you don't ever have to touch the glovebox at all to get to it. It's under the dash area next to the motor which is mounted at the bottom of the ductwork. It's partially hidden but if you get your head under the dash far enough, you can see it. Using an 8 mm socket, 3" extension, and ratchet, 2 screws and it's out. Hope this info saves someone some time. After I figured out it wasn't behind the glove box, the job went quickly. Part is a bit over $40.
Old Apr 24, 2013 | 06:59 PM
JWC 3's Avatar
JWC 3
Glad you found the fix . Thanks for posting it !
dethomson
Sep 6, 2011 03:16 PM
2001gocougs
Dec 27, 2006 01:39 PM
dieseldoo
Mar 6, 2006 06:59 PM
DaveWW00
Nov 10, 2005 10:49 PM
bjolie
Feb 9, 2004 08:44 AM
