Sponsored by: Auxito
97 f150 techincal service bulletin 9747
Old Jun 5, 2003 | 09:13 AM
z 97ford1's Avatar
z 97ford1
Does anyone know anything about TSB #9747??????
Something about the frame/structure rivets or bolts should be replaced.
I know my 97 4x4 will "pop" or squeak real bad if I'm driving on uneven roads......like the frame under the transmission is moving or sliding.
(Green chile/Guacamole) blaaaaaaccc.....give me a T-bone, plane
Old Jun 6, 2003 | 12:39 AM
Racerguy's Avatar
Racerguy
TSB 97-4-7 says basically that if you find a loose rivet on your frame to replace it with a bolt and nut. It gives details on how to drill it out etc.
Have you tried tightening your transmission crossmember? Torsion bar crossmember?
Old Jun 6, 2003 | 02:00 PM
z 97ford1's Avatar
z 97ford1
Have not done anything yet but will look at it this weekend.
Is there some way I could get a copy of the TSB?
Thanks
Old Jun 6, 2003 | 08:30 PM
Racerguy's Avatar
Racerguy
It's not a very exciting TSB......
ISSUE:
Damaged or loose frame rivets should be replaced with approved service bolts. WELDING IS NOT ACCEPTABLE.
ACTION:
If service is required, replace standard rivets with approved service bolts. Refer to the following Service Procedure for details.
SERVICE PROCEDURE
NOTE: THE "HUCK" RIVET BETWEEN THE #1 CROSSMEMBER AND THE LH FRAME RAIL SHOULD BE SERVICED PER TSB 91-25-18. THIS PROCEDURE DOES NOT APPLY.
Inspect for a loose or damaged rivet.
Remove any damaged or loose rivets.
Drill a 3.175mm (1/8") hole through the rivet.
Redrill the same hole through the shank of the rivet.
Use an 8.731mm (11/32") drill for 3/8" and 10mm rivets.
Use a 9.525mm (3/8") drill for 11.113mm (7/16") rivets.
Remove the rivet head with an air chisel.
Drive out the rivet with a punch and hammer.
Line ream the hole to the replacement bolt nominal size with a hole tolerance of ±0.127mm (0.005").
Free hole of burrs after reaming to allow bolt head and nut to seat properly.
Select the bolt length to have a minimum of two (2) threads protruding from outer face of nut. Refer to the following Bolt Selection Chart for correct parts usage.
NOTE: IF A FLANGE HEAD NUT AND BOLT ARE NOT AVAILABLE, GRADE 5 HEX HEADS MAY BE SUBSTITUTED WITH ONE (1) FLATWASHER REQUIRED UNDER THE NUT AND ONE (1) FLATWASHER REQUIRED UNDER THE BOLT HEAD.
Check to be sure there is a 12.7mm (1/2") minimum clearance of bolt to adjacent components, except engine and transmission, which must have at least 19.05mm (3/4") clearance to allow for powertrain roll.
Tighten the bolts to the specifications shown in the Bolt Selection Chart.
NOTE: GRADE 8 BOLTS MAY BE SUBSTITUTED FOR ANY APPLICATION.
BOLT SELECTION CHART
Rivet Diameter Bolt Size Bolt Part Number Washer Part Number Nut Part Number Torque Specifications
3/8" and 10mm 7/16"-14x1.25" 56561-S2 Not Required 382400-S2 45-68 N-m (33-50 lb-ft)
7/16"-14x1.75" 56563-S2 Not Required 382400-S2 45-68 N-m (33-50 lb-ft)
7/16" 1/2"-13x1.5" (Grade 5) 56783-S100 Not Required 33773-S2 72-102 N-m (53-75 lb-ft)
1/2"-13x2.0" (Grade 8) 383896-S2 44879-S2 33773-S2 102-142 N-m (75-105 lb-ft)
CAMiniTruck
22
Feb 7, 2014 10:44 PM
JRM1972
16
Mar 11, 2013 08:59 PM
ksmith203
15
Feb 17, 2007 02:58 PM
