Is this a flat tappet or roller cam?
Yup I am an idiot. I didnt mix these up as in side by side or anything. I simply cant be sure which is which. That what happens when projects take to long and/or you forget to mark shìt.
I need to know if this is a newer or older cam from a 302. Thanks!
Yep, that's backwards. That looks like a roller cam to me based on the even wear pattern across the lobes. Flat tappet cams exhibit a much different wear pattern, favoring one side of the lobe, where the lifter rides that side, this imparts the rotation in the lifter. Post the numbers (and letters)stamped into the rear of the cam.
Somethings wrong with this cam I think... Its really stiff. All assembled it takes about 90 ft lbs of torque to turn crank and # 8 piston isnt installed yet. (Waiting for replacement rings)
It seems that the cam really tightens with the lifter retension tray installed. Its good n snug regardless. Doesnt make sense its the tray as the lifters slide freely. The bolts for the tray thread into a hole that has a bottom.
I don't know... Seems tight. Might just need broke in?
Now that you've posted that second set of pics, that may be a flat tappet cam. Post pics of both cams. The roller will have lobe peaks that are more rounded than a flat tappet cam. As for "generous amounts of moly grease" on a flat tappet cam, that's exactly what you don't want. Nor on a roller cam. roller cams need no prelube, other than oil. Only thing I use moly grease on there is the distributor gear. The motor will be increasingly harder to rotate as each piston goes in, did you dip them in oil before sticking them in the hole ?
