Oil Leak ??? :(
Old Jun 10, 2003 | 12:46 AM
The Diesel Dude's Avatar
The Diesel Dude
Oil Leak ??? :(
Because of the turbo "pressure feeding" the engine the compression ratio has been dropped to about 17:1 (I'm not sure exactly what it is off the top of my head) to prevent head gasket failures at full boost full load conditions, instead of 21 or 22:1 on a naturally asperated diesel. So, at no load conditions, not all of the fuel is burned. Eventually, some of it will be expelled into the exhaust system (during long periods of ideling) and if your turbo pipes are not a liquid tight seal, some of it will "drool" out the exhaust joints and make a mess. It is not oil leaking (although it looks like oil), it is actually fuel.
Old Jun 10, 2003 | 12:56 AM
The Diesel Dude
Oil Leak ??? :(
Originally posted by steveepp
I have this same leak in a 2001 PSD. I'm almost sure it is coming from the turbo pedestal. It seems to have not been as bad sense it has gotten hotter here in Texas. So.....I'm sure it is the pedestal!!!!
The turbo pedestal is not the best design (they should have used 4 bolts instead of 2 to hold the turbo to the pedestal). I think the situation could be improved if you installed helicoils in the aluminum pedestal and 10.9 or 12.9 grade bolts torqued to the maximum torque rating for the bolt grade you are using (I'd use 12.9's torqued to 55 to 60 ft.lb.)
94 7.3idi
Nov 9, 2012 01:53 AM
2catch22
Sep 18, 2012 12:14 PM
stang70
Aug 25, 2011 11:13 AM
Towster
Jul 28, 2011 06:52 AM
pbrowning
Electrical Systems/Wiring
Jul 10, 2006 09:39 AM
