Sponsored by: Real Truck
Dash section removal
Old Apr 18, 2013 | 04:39 PM
sailorman3's Avatar
sailorman3
I'm installing a OEM trailer brake controller in my 2013 F250. I need to remove the coin holder in the dash that is right next to the upfitter switches. Could someone give me some direction on how to do this. Thanks in advance.
Old Apr 18, 2013 | 05:12 PM
redford's Avatar
redford
FTE Leadership Emeritus
Doesn't it just pop out?
Old Apr 18, 2013 | 05:33 PM
sailorman3's Avatar
sailorman3
It looks like it might, but I don't want to try prying with a screwdriver and risk breaking the clips.
Old Apr 19, 2013 | 03:55 AM
sailorman3's Avatar
sailorman3
Anyone. I really don't want to break the dash parts and clips when taking the section for the break controller out.
Old Aug 13, 2013 | 08:07 PM
DaveNTx's Avatar
DaveNTx
Did you have any luck in removing the coin holder? I've got the same the same situation and can't figure out how to get the thing out of the dash.
Old Aug 13, 2013 | 08:22 PM
sailorman3's Avatar
sailorman3
Pop out the piece that has the audio jack in it and there is a bolt inside that has to be removed. Also there is a piece across from it on the other side of the coin holder that has to be popped out. Inside another bolt to be removed. The dash can the be pulled out enough to get your hand up inside to release the coin holder clips.
Old Aug 16, 2013 | 04:52 AM
bikerman2299's Avatar
bikerman2299
If you pop out the Aux input on the right side of the dash, next to the coin holder/upfitter switches you can reach behind the upfitters/coin tray and pop it out. Once that is out you reach behind and get to the clips on the back. When I did my upfitter switches install, I just wrapped my screw driver in a rag to keep from damaging finished. The coin tray popped right out when I pried from the bottom. If you have any other questions, I can email you a PDF that covers the upfitter installation. It would be the same for the trailer breaks controller as far getting access to that area.
slivinski
Apr 3, 2019 05:09 PM
rebel112r
Feb 26, 2010 06:40 PM
JSPajak
Jan 12, 2008 11:49 PM
RBG
Appearance & Dress-Up
Dec 29, 2003 05:50 AM
