Excursion Hitch!
Old Apr 17, 2013 | 12:08 PM
Excursion123's Avatar
Excursion123
Smile Excursion Hitch!
Hello guys i got another hitch from a Tennessee salvage yard.
As you can see it is very rusty on the surface. What is the best way to remove/paint over this surface rust? What kind of paint or chemicals do i need? Thanks alot.
Old Apr 17, 2013 | 12:54 PM
Archion's Avatar
Archion
Veteran: Marine Corps
I would try to have it media blasted it and powder coated it, but that's a personal preference. YOu could always wire wheel it, and primer/paint it.
04fivefour's Avatar
04fivefour
Easiest way or quickest way ive found is a grinding wheel with a 36grit wheel on it. gets it to bare metal quick.
Old Apr 17, 2013 | 12:58 PM
hav24wheel's Avatar
hav24wheel
Wire wheel to take the loose stuff off, and use POR15 on it
Old Apr 17, 2013 | 01:04 PM
luckydog2950's Avatar
luckydog2950
Excursion123, Ideally I would have it sandblasted then powder coated.
Plan "B" would be sanding or wire brushing the loose stuff then coating it with OSPHO or some other type of metal conditioner then paint with preferably something that is a 2 part catalyzed paint. Also I don't have any experience but maybe someone else on the board can help with is a product called POR-15 which from what I understand you can apply directly over rusted metal.
Old Apr 17, 2013 | 03:11 PM
WE3ZS's Avatar
WE3ZS
Another vote for blasting and powder coating, if I ever have mine off thats what I'll do to it. For now I just keep a coat of Rustoleum on it every year or so.
Old Apr 17, 2013 | 04:56 PM
hav24wheel's Avatar
hav24wheel
Way way cheaper to wire wheel and POR-15. It's a good product, and is very strong. I've never had good luck with powder coating. Just look at trailer wheels, pickup flat beds and stuff after a couple years
Old Apr 17, 2013 | 05:29 PM
xbox73's Avatar
xbox73
Another vote for a cheap method for surface rust removal, followed by POR-15.
Old Apr 17, 2013 | 05:55 PM
Saddle-tramp's Avatar
Saddle-tramp
Yep, PaintOverRust-15.
Old Apr 17, 2013 | 05:58 PM
ExxWhy's Avatar
ExxWhy
Whew, that looks pretty rough, especially coming from TN. Make sure you get the inside cleaned up and painted as well.
airjeff
Oct 6, 2012 02:55 PM
FloridaFordGirl
Florida Chapter
Oct 24, 2011 03:10 PM
wedge88
2004 - 2008 F150
Apr 8, 2009 03:53 PM
curt9999
All Things Towing
Mar 20, 2009 12:02 AM
Fordcr
Jul 11, 2003 05:06 PM
